Question about Ovens
I need tech support on a market forge ST-6E steamer the heat indicator is on, the ready light (green) will only stay on for about 10mim.
    President:
  • 1,723 Answers
A clean generator light indicates when it's time to delime. Generators can be easily cleaned from the outside of the cooking compartment, through a port on top.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 29, 2009
  • Craig Butler
    Craig Butler Jul 29, 2009
    Remove lower front panel and see
    if all the heating elements are working.
Oven comes on but no heat the ready light lights up no heat
* Thermostat problem or burnt out heating element.
* Check your warranty and call for service.
*** warning High voltages or flame explosive hazard (gas stove)
* For gas stove call your gas company. The Gas techs are usually familiar with most gas appliances. The can check your gas supply and your stove.
* Be safe. Call for service.
Aloha, ukeboy57
Jun 06, 2018 | Ovens
Hi I have an old 1970's St.george imperial wall oven and I can't turn the roast light off which makes the oven heat up to under half the heat it normally does. How do I turn the roast light off?
since I have no model or serial, I assume this is an electric oven based on the description provided. this is usually an indication that the heating element has gone bad. possibly having a short to ground which completes a partial circuit in turn giving you heat and a light. I would look in this direction first.
Jan 04, 2018 | Imperial Ovens
The "element on" indicator light
It the indicator light on all the time? Or after cooking and you turn the elements off the light stays on for a long time but it does eventually go off?
Mar 04, 2011 | Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
My indicator lilght stays on even when the burner is off.
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Dec 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is showing a code E3 (in red) -F1- (in black). Everything works but the heat light will not stay on and it will not heat. It has a safty feature that when the electricity goes off you have to reset...
This indicates a failure in the temperature probe. This is easy to check and replace. Here is a link that will walk you thru checking and replacing an oven Temperature Sensor .If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
Nov 09, 2010 | Whirlpool Ovens
Thermastat or element ?
Could be both parts are faulty from symptoms you describe.
The indicator light should not be on if it is in the off position, this would suggest the thermostat is faulty.
On the other hand, if the element is faulty, then obviously, there will be no heat
To be certain if the element is faulty or not, then you need to test the element with a meter.
Jan 20, 2010 | Baumatic B180 Electric Single Oven
My hot light stays on and every thing is cool to touch
yes , hopefully you have a seperate indicator light for each of the elemnts, makes it easier to see which has gone bad, but if yo know which burner you were usins at time of incident then you can assume that it was that elemnet. replacement of the elemnt is required, for a it has a short in the theremistor, not a hazard, more of an inconvience, so i would have it taken careof but no need to rush its not an emergency, its only an faulty indicator, the elmnt is not actually heating
Mar 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
76 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
