2003 Jaguar X-Type Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cutting out when driving (glow plug light start to flash)
Rajath Johnny
Level 2:
  • Expert 250 Answers
  • Posted on Jul 29, 2009
Rajath Johnny
Expert
Level 2:
Answers
250
Questions
Helped
122349
Points
831
Check fuel pipe from tank.there might be some or sever kink.Also worth a chat at fords as they have a lot of exp with mondeo.check the air filter,it might be blocked.this problem also occurs when the ECU gets locked up.check the glow plugs if they are ok then you need to calidrate your injectors.
Glow plug light flashing
the glow plug are used to heat the fuel on start up only, as a diesel uses compression instead of a spark (from the spark plug) have you try checking the connection on the glow plug, or changing the glow plugs themselves?
Glow plug light wont go out
Your diesel vehicle is equipped with glow plugs, and also with a Glow Plug Light that will either come on and stay on, or flash or blink when a fault is detected by the ECU (engine management unit). When the Glow Plug Light comes on, the ECU stores information about the condition that has caused it to come on.4 Jan 2016
Is It Safe to Drive With the Glow Plug Light On? ' YourMechanic Advice
https://www.yourmechanic.com/article/is-it-safe-to-drive-with-the-glow-plug-light-on Glow plug light wont go out Google Search
Glow plug light
Glow plug light? I didnt know Ford made a Diesel Focus?
2answers
Diesel engine cuts out and glow plug comes on please help
does the glow plug/coil light flash at all???? once would indicate glow plug relay fault! three times would indicate FUEL pump failure! sorry never experienced two flashes....
Kind regards
3helpful
Ford Focus TDCI cuts out when driving -glow plug indicator flashe
factory immobiliser playing up ,get a new ECU unit with the chip out of the key and the key reader
Glow light flashing
If I'm not mistaken in the MK4's (2000 and up vdubs) if your glow plug light is flashing there is a fault in the system you should get it service asap. It won't hurt by driving it like this but it will be harder to start on cold days/mornings.
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
