Question about Minolta magicolor 2200 DeskLaser Printer
Adjust Upper Bin displays on my printer
It worked fine until I tried printing on photo paper in the upper bin. Then I realized that the upper bin did not take in paper -- I didn't know as I have never used the manual feed tray. I changed the settings in the printer to manual feed for this purpose. Once I realized that it did not work, funny because I bought the printer new and never used it, I set the setting back to multipurpose bin, restarted both computer and printer trying to clear out whatever makes it think that I want the manual feed bin, but no luck. Any ideas? My email is
  • 81 Answers
Re: Adjust Upper Bin displays on my printer
How old is your machine? check if the printer supports that thickness. if so check the setting of the printer if it match with your actual paper. if your printer is older and your place is dusty try to clean the rollers under/inside the paper tray.
i hope this will help.
Posted on Mar 10, 2008
0 characters
3 Points
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
Sep 21, 2011 | HP Hewlett Packard LaserJet 5550n Printer
Can't find the paper that is jammed in the printer (laserjet 2600n) its says its in the output bin
The output bin sensor check the quantity of printed paper that remain in the upper part of the printer. When the paper is too much, the sensor report a paper jam.
Check the lever of the sensor in output bin if it's working properly
Jun 15, 2011 | HP Color LaserJet 2600n Printer
Paper cassette is not seated correctly. check for paper or objects blocking the cassette path. reinsert the cassette and press Start. keep getting this message. started after printing and installing...
I had this same problem and tried everything (I thought) to fix it. Then I saw the solution at:
Basically there is a plastic pin that tends to break off and stays in the area where the cassette is loaded. It takes up just enough space to keep the cassette from being pushed in all the way. The solution is to turn the printer off, unplug it, then lift up the printer so the broken pin falls out. Once it comes out, the printer will work fine again.
May 12, 2011 | Epson Artisan 800 All-In-One InkJet...
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Aug 25, 2010 | Epson Printers & Copiers
Sound like the paper size is set to 4x6 photo size. Check the settings on the printer settup display.
Mar 29, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Optra S2455 output bin control
I used the Optra W810 driver. It had listing for *UPPER and *LOWER for the bins....
So..I took a chance on the following
Output Bin
Sel Cmd Description
1 3 Output Bin 1
2 4 Output Bin 2
*LOWER 2 Lower Output Bin
*UPPER 1 Upper Output Bin
3 5 Output Bin 3
All is goo!
May 22, 2008 | Lexmark Optra S 2455 Laser Printer
Minolta Photocopier EP5000
the non sort bis is the first bin from the top, and by the mean time you can see a hole in the bins for sensing the papers in the bins, the hole from the first bin to the last bin should be un obstructed, as the sensors are on the upper frame and the receptor sensor in the lower frame. so check for any obstruction between theese two sensors through the holes on the output bins
Mar 13, 2008 | Printers & Copiers
Minolta magicolor 2200 DeskLaser Printer Logo
239 people viewed this question
Top Minolta Printers & Copiers Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Printer and Copier Expert? Answer questions, earn points and help others
