Try this site. might help. 26789020 SOLVED Valve clearance for ade 366
SOURCE: Escort Mk2 1600 valve and torques settings what are they
cylinder bolt torque settings stage 1 15 ft pounds
stage 2 50 ft pounds
stage 3 85 ft pounds
valve clearences 0.15 - 0.20mm inlet
0.22 - 0.27mm exhaust
these are the figures i have been supplied with, you can also use
cylinder bolts stage 1 10 ft pounds
stage 3 + 90deg.
with my exp, i would use the first guide as the degree method has a tendancy to snap head bolts, especially on older vehicles.
SOURCE: how to adjust valve clearance on a 1999 sunfire
There is no valve adjustment for that engine, Hydraulic lifters, You might remove the valve cover and see if you have a rocker arm loose
SOURCE: can you set valve clearances on a 1997 clio 1.2
Hi
If your engine type is D7F
ADJUSTING THE VALVE ROCKERS
Adjustment values (cold engine) (in mm)
Inlet 0.10
Exhaust 0.20
Tilt method
If this is not your engine do not adjust, Please feel free to provide me with your engine type for correct adjustments,
SOURCE: whats the valve clearance for toyota 4k engines
valve clearance is .20mm for the intake and .30mm for the exhaust. Will try to find cylinder head torque for you.
