Question about Marvel (6SBARBSG) Wine Cooler
Unit does not run due to faulty thermostat. - Marvel (6SBARBSG) Wine Cooler
    Novelist:
  • 101 Answers
The 6SBAR-BS-G most likely has the solid state thermostat that consists of three parts: A solid state control board, a 0-100K potentiometer (connected to the control dial) and a thermistor. The thermistor is the most common part to fail. I would call the factory and ask for technical assistance to help isolate which part has failed. Most service companies do not stock their parts. The factory's number is 800-428-6644 or write an email to marvel@marvelindustrie.com
Posted on Sep 14, 2009
Car is dieing when i slow down
run the fault codes as the engine temperature sensor unit that controls the ECM may be faulty from the over heating that was occurring.
Mar 15, 2014 | 1990 Buick LeSabre
P1281 code
n most cases it will be due to a bad thermostat, but yes. A faulty temperature sending unit could possibly fool the computer into thinking that the engine did not warm up properly. They have this one worked out pretty well though. The computer is likely to get suspicious of an engine that has been running 20 minutes and still hasn't reached normal operating temperature.
Jul 27, 2012 | 2001 Dodge Durango
Won't run when set to auto
This can either be a bad thermostat or faulty control board. If the unit kicks on after jumpimg the wires at thermostat then the thermostat is defective, if it does not turn on the control board is faulty and must be replaced.
Jun 06, 2012 | Goodman Heating & Cooling
Ice on suction line
hello, usually the suction line will form ice when there is low airflow due to a dirty filter or plugged eveaporator coil, also if the unit is clean then it is possible that the unit is low on refrigerant charge due to a leak. Inwould also check the thermostat on the unit to make sure it is fuctioning properly, I have seen may units where the thermostat cause the compressor to run continously and cause the suction line to freeze.
Jun 14, 2011 | LG Electronic Window Air Conditioner
I have Model#733308866. The fan runs but the compressor does not. I want to repl the thermostat to see if that fixes the issue. What is the correct part that I need to order
Hi, I wouldn't replace the thermostat if the compressor isn't running. I don't know what kind of system you have, but normally when a compressor does not start and run, it could be a faulty run capacitor, the compressor may be shorted internally, no power to the compressor due to the run capacitor. I wouldn't waste the money on a thermostat until you find out what is causing the compressor not to run. Normally, it would not be the stat. If I knew the name of the unit, and if it were a central heating and cooling system, or a wall or window unit, this would help in trouble shooting it, but when a compressor does not start, its either a bad compressor, run capacitor, or its off on its overload due to loss of freon, drawing to high of amperage, Ect. These are things that need to be checked if you are able to do this kind of work with your hands and have some experience with electrical trouble shooting. So, if you can, look at the run cap to see if it is swollen, leaking oil, or deformed, put your hand on the compressor after the unit has been on for sometime to see if it is hot, be careful not to burn your hand. This will tell you there is a problem internally in the compressor. Please keep me posted.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Sep 15, 2010 | Heating & Cooling
My fridge is freezing everything. I've had on lowest setting, highest setting, in the middle. I can't work out what I need to do. It's a Samsung model. About 7-8 years old. Don't know the model...
Hello and Welcome to FixYa!
I would suggest you to check for the thermostat unit and replace it if faulty. Actually the symptoms you quoted in the query shows that either the thermostat of the unit is faulty or it could also happens due to leak in the sealed (refrigerant ) system,cold air migration (in case of side by side refrigerator) or a defective air damper. But first thing you should check for is the thermostat unit.... A rough technique to check the thermostat is by observing the unit.... If the unit trips periodically then the thermostat looks fine... If the problem still persists, the thermostat needs to be checked electrically, but we'll discuss it if required...First check for the quoted possibilities.
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 17, 2010 | Samsung Refrigerators
Split system Celestial turn off for a while when runnig and then turns back on again head unit continues to run power light has been flashing when this happens.
Turn off while running and then turn back on again, causes electrical control circuit system was malfunctioning due to overload relay trip off and then this will trigger on when the load was cold setting the unit run again.Overload tripping off due to there's a high current flowing in the circuit w/c is higher than the rated current specified in the unit.Several factors may be consider the head unit is developing hi pressure that causes electrical circuit malfunction.or the thermostat is defective or some thermostatic valve is mulfunctioning.
Feb 19, 2009 | Heating & Cooling
Hotpoint FFA70P Bottom freezer not working
HI The thermostat control is usually mounted inside the refrigerator. Its visible control knob is turned to regulate the refrigerator/freezer temperature. The workability of this control can be tested in various ways, depending on the problem. To test the thermostat control:
Step 1:
 If the compressor runs all the time, turn the control knob to the OFF position. If the compressor still runs, unplug the unit, then pull off the control knob and remove the screws holding the thermostat in place. Pull out the thermostat and remove either the red or the blue wire from its terminal. Plug in the unit. If the compressor doesn't run, the thermostat is faulty. Replace it with a new thermostat.
Step 2:
If the compressor runs after the wire is removed from its terminal, there is probably a short circuit somewhere in the unit's wiring. In this case, don't try to fix the problem yourself; call a professional service person.
Step 3:
If the refrigerator or freezer runs but the box doesn't cool, unplug the unit and remove the thermostat with a screwdriver. Disconnect both wires from the thermostat. Tape the ends of the wires together with electrical tape, and plug in the appliance. If the refrigerator starts and runs normally, the thermostat is faulty. Replace it with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 4:
If the freezer compartment is normal but the refrigerator box doesn't cool, set the dials that control both compartments to mid-range. Remove these knobs (they're usually friction-fit). Then unscrew the temperature control housing; you'll see an air duct near the control. Replace the knob on the freezer thermostat and turn the control to the OFF position. Open the refrigerator door and look closely at the air duct. If this duct doesn't open wider in about ten minutes, the control is faulty. Replace the control with a new one of the same type. Connect the new control the same way the old one was connected.
Oct 07, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Marvel (6SBARBSG) Wine Cooler Logo
282 people viewed this question
Top Marvel Furniture Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
