Question about Sentry Fireproof Safe
How to unlock my safe
I have a nugue safe box. i lost the combination codes and i can't get to open it. Can i get some help
    Sergeant:
  • 293 Answers
Check at the bottom of the box if there is a screws, if yes, unscrew and open it, then remove the battery. you will see also the default code back of the cover. ok
Posted on Jul 29, 2009
I have a sentry fw123cs safe. It's open but i can't find the owners manual to ock and unlock i
Go to the Sentry safe website, http://www.sentrysafe.com/CustomerCare/Find_Your_Safe and click on "lost your combination" and they should be able to help you retrieve yours.
Aug 29, 2014 | Sentry Safe SentrySafe Model SFW123CS...
Lost combination
You need to call sentry and to give them model number, they will give you an unlock code.
May 22, 2008 | Sentry Fireproof Safe
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost.
Check the attached links,instruction and guides on how to open your safe. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SFW123CS Combination Fire Safe
http://content.etilize.com/User-Manual/1027349209.pdf
How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431...
Emergency Locksmith Services Aim Lock Safe
Jan 21, 2012 | Sentry FIRE-SAFE Combination Safe DS3431,...
What is the code in enterfactory
Hi.
Hi. There is no factory fixed code. Thieves would be the first to benefit from such feature! The factory code is uniquely associated to the safe serial number and it is stored in Sentry protected database. When original code is lost the only way to unlock the safe is bay following Sentry's procedure.
Contact Sentry immediately. They will first try an emergency unlock code, and then they will give you instructions in case the safe must be serviced. Here the contact: Call or Email Us
Here general instructions about what to do when combination does not work. Instructions are addressing lost combination.The procedure is the same in all cases when combination does not work (malfunctions, lost combination etc.) . Please contact sentry and follow procedure to get the safe open.
Regards.
Ginko
Oct 05, 2011 | Sentry Fireproof Safe
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
Lost combo sentry v530
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 27, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
See also:
Apr 18, 2009 | Sentry Fireproof Safe
Lost combination Safe Guard Digital Safe
I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade.
Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
Jan 29, 2009 | Safe International Digital Electronic Safe...
Sentry safe
u can request a lost combo from the sentrysafe.com u gotta get a it noteiatized and send it in to them the details are listed on the webpage i hope this helps u
Aug 25, 2007 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
175 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
