Question about Adapters.com Computers & Internet
After charging d battery when we remove cabele
After charging d battery when we remove cabele then system get turnoff what's d problem
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 55 Answers
The battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Posted on Aug 18, 2009
Charging system voltage
connect a pair of jumper cabells to the gen connect the pos to the gen side of the gen and the negative to the feald side and hook them to a hot car batt momentarley do not do wial running . should stop probleam good luck
Aug 05, 2013 | 1979 Harley Davidson XLH 1000 Sportster
Car gages all turn off and than turn back on a few miles later
Do you have an aftermarket stereo system? these cause a tremendous strain on your alternator which may be the problem. Check all connections to alternator, battery, and ground cables. the alternator will provide enough power to run your vehicle if it is working properly. If it is faulty, it will drain your battery. take it to an auto parts store to be tested before purchasing a new one, because it could be as simple as a loose or corroded wire.
Jul 11, 2012 | 2003 Ford Focus
I have this dig camera but have no cabels and would like to know where to buy them and if I need a separate cabel to charge or is that done on the computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as iPhoto and Windows Photo Gallery.
The X029 uses three standard AAA batteries. You may use either disposable or rechargeable batteries. If you choose to use rechargeables, you must charge them outside the camera using a separate charger.
Dec 04, 2011 | Vivitar ViviCam X029 Digital Camera
I replaced the altenator and the battery and the battery light is still on and the car shuts off if i remove the battery cabel i have checked the fuses and none of them were blown
have to test battery to see if its getting voltage from alternator. put voltmeter on battery while car is running give it a little gas 2500rpm and check voltage should be 13 or over if not alternator is bad, if it is then shut car remove battery and take to auto store have them load test battery, or if u have a load tester , charge battery until full charge, connect tester and hit load switch for a couple of seconds , if it falls to red area then battery has a bad cell.
Apr 07, 2011 | 1992 Ford Tempo
How do you remove battery in Acura MDX?
first turn off the car then u must remove the negetive cabel u do this my a bolt that is connected to clap around the post after these remove the positive cabel then you may lift the battery out of the batter box make sure to have no mettelice jewley on when u do this and when you use the wrench or ratch to not touch the fram of the car or any thing else metle
Jan 28, 2011 | 2004 Acura MDX
Hp pavilion dv2000 Turnoff due to overheating
1) plz go to power options from control pannel and change the power options as never never
2) we can do one more thing,we can do a Bios update
everything tis going to fine
ITS Works
Dec 06, 2009 | HP Pavilion dv2000t Notebook
Mix max won't play music, turnoff or charge
If it is not recognizing by the computer, not turning off, or recharging, then you have a problem with the battery in itself (or battery related components).
You probably won't be able to get a battery replacement for that unit.
With anything, when a computer system, router, MP3 player, IPOD, etc. has problems functioning correctly, there is more than likely a power issue with the unit.
Aug 06, 2009 | Disney Mix Max Digital Media Player
Battery not charging
Was it charging ok before the damage occured?
Oct 22, 2007 | HP Pavilion zd8000 Notebook
Bios problem
Hi Unplug the power cabel on your computer and remove the battery on the motherboard and then place it back. Good Luck
Sep 16, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
170 people viewed this question
Top Adapters.com Computers & Internet Experts
JP Services
JP Services
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
