Question about Fuji FinePix J10 Digital Camera
Removing battery for charging - Fuji FinePix J10 Digital Camera
    President:
  • 423 Answers
Open the battery/memory card door on the bottom of the camera by sliding it towards the end of the body. Move the plastic, orange, locking switch away from the battery. The battery should then spring up slightly, enough that you can pull it out with your fingers. When you re-install the battery, make sure to put the contacts on the battery into the camera, making sure to line up the battery's orange stripe with the orange lock switch on the camera. If you need to use any force, you're doing it the wrong way.
Posted on Aug 08, 2009
Battery light flashing red
If you are using AC, remove battery. Charge battery and remove when plugged in for a period of time. It will last longer, the battery has a finite number of charge cycles.
May 17, 2013 | Acer EXTENSA 4630Z COMPATIBLE LAPTOP LCD...
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Feb 24, 2013 | Computers & Internet
Should I remove Nicads from charger after charge
That depends entirely on the charger. Cheap chargers will not shut off power to batteries even when they are fully charged. Nicer chargers will cut power to the batteries when they are charged up.
But the safe answer is yes, remove batteries once they are done charging. (And store batteries with a full charge.)
Apr 21, 2012 | Drills
My vivitar x345 wont hold charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 23, 2012 | Vivitar ViviCam X345 Digital Camera
Motorola v365 won't charge and won't stay with wall power
The reason your phone wont charge might be because there is a problem with the battery, the charger or the charging port.
To test it if it is the battery,
Insert the battery into another phone and try to charge it for a while,
if it does not work, then it is the battery.
All you have to do is to change the battery.
To test it if it is the charger,
Plug the charger to a power supply,
Connect the charger to another phone, to see if it works.
If it does not work, then it is the charger that needs replacement.
To test if it is the charging port,
Insert a new battery, and plug it to a new charger.
If it does not charge, then it is the charging port.
Replace the charging port and it will be okay.
To replace the charging port;
  1. After removing your back cover and battery, remove the four torx 6 screws you see. (When reassembling, the gold screws go at the bottom and the silver screws go back at the top),
  2. With the four screws removed you can now remove the battery compartment,
  3. With the battery slot removed you have access to one of the ribbons which connects the screen to the main body of the phone. Unclip this (it fits like a plug and socket).
  4. You'll now have the phone in two parts,
  5. Take to the lower part and disconnect the charging port and replace it with a new one,
  6. Reverse the whole procedure for reassembly
Take care
Jun 19, 2010 | Motorola Mobility V365 Cellular Phone
After charging d battery when we remove cabele
the battery sounds like it has bad battery memory and needs to be replaced. Before you replace it look for software to give you the battery's status (how much charge it holds out of how much it should hold by design. for exaple i am using ubuntu linux and my battery reads
Capacity: 29% (Poor)
Current charge: 14.3 Wh
Last full charge: 14.3 Wh
Design charge: 48.8 Wh
Charge rate: 10.0 W
now that is my bad battery for staying at home and leaving it plugged in all the time (that kills the battery) i have another battery that reads
Capacity: 97% (Good)
Current charge: 38.8 Wh
Last full charge: 47.5 Wh
Charge rate: 5.5 W
it is my battery for travel. the difference between the two is that the battery that reads Capacity: 29% (Poor) only lasts about 40 minutes but the battery that reads Capacity: 97% (Good) lasts 3 hours. you probably have a low Capacity.
Jul 29, 2009 | Adapters.com Computers & Internet
My HDD065 will not charge and is not recognised by my PC. It is about 2 years since I last used it. Any suggestions? H
If you let the battery get too low, the battery will not charge because the motherboard does not have enough power to control the charge process. There are two ways to fix this. 1) buy a new battery that will be supplied fully charged. 2) borrow a friends HDD065, fully recharge the battery and remove it. Place the battery in your player and turn it on. Put your player on charge. Without turning your player off or removing the charger, remove your friends battery and place yours in it. It may take a couple of attempts but you should be able replace your battery and keep the player operational. Leave your battery to fully charge.
Jun 24, 2009 | Philips HDD065 MP3 Player
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
Fuji FinePix J10 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
