I have Netflex on my computer, but think there should be a way on my Emerson TV
SOURCE: emerson remote for emerson tv/vcr combo
Emerson TV codes 0154, 0236, 0463, 0180, 0178,
0171, 0623
Emerson TV VCR Combos 0479, 1479, 1278
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
SOURCE: Remote code for Emerson SLC195EM82 TV
Here is a list of remote codes for Emerson TV: 004 009 014 023 024 025 026 027 030 032 033 034 035 036 037 038 039 040 041 042 043 045 046 049 053 116 135 147 177 179
Give them each a try (a pain I know) and please rate me if they work!
Take Care,
-WN
SOURCE: Emerson TV LC320EMXF Remote code for Direc TV
I got the same TV for my stepdaughter and had the same problem. None of the Emerson codes worked. We use Dish Network but I did the autoscan thing on the remote and found that it was 672 which is listed as a Sylvania. I don't know if it will help in your case but maybe try the Sylvania codes. Good luck.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
