Question about Kenmore Oasis HE 27082 Top Load Washer
When the washer is finished washing. what does hc mean
  • 15,935 Answers
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
What does the HC code mean on the Maytag Bravos Quiet Series 300 mean?
You can fix it. Your hot and cold water hoses are reversed on the water valve on the washer. Switch them around you should be fine.
Sep 08, 2014 | Washing Machines
SYMBOLS ON THE PANEL
That means that you have the hot and cold hoses hooked up to the wrong inputs. Switch them.
Feb 02, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer shows a code HC...what does this mean?
HC will flash when the hot and cold inlet hoses are reversed. Make sure your inlet hoses are connected correctly. That should correct the issue.
Jun 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a kenmore elite oasishe washer and it keeps setting off messages that I am not sure the meaning of. It finished washing the other day and it had hc on the machine what does this mean?
May 21, 2010 | Kenmore Elite 45986 Front Load Washer
My washer shows a HC in the panel. what does that
HC means that the Hot and Cold water lines are reversed. Make sure that the supply hoses are connected correctly. If they are, then there is a problem with the sensor or control board.
Apr 28, 2010 | Kenmore Oasis HE 27082 Top Load Washer
HC code is on the front when it finish washing the clothes
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$#@
Nov 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
What is the HC code for the washer . It comes on after the wash cycle is finished.
After replacing the part to fix the F1 code, the washer (Oasis he) now comes up with a HC code. Also, even though the cycle is set for warm/cold, the clothes are coming out hot at the end of the cycle...and the cold water is hooked up and on. Any suggestions?
Sep 08, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
162 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
