I don't know what else is on the circuit with your Dishwasher, but it is possible that you have a defective circuit breaker, or corroded wiring at the circuit breaker or at the dishwasher. Maybe too many gadgets on he same circuit and you are tripping the breaker. The dishwasher may have an internal circuit breaker that needs replacing. some thing to think about.
Ernest, how can I ask a follow up question I attempted to add comment but that did not work
The DW is the only appliance on the circuit breaker. The service guy stated that if it is a DW fuse then turning the circuit breaker off then on would not allow the DW to work. I had asked about that. Anything else?
It could still be a bad circuit breaker. Try swapping it with another one the same size. I had an air conditioner dropping out. The circuit breaker looked ok but replacing it solved the problem. If you have a volt meter check the output from the breaker the next time it stops.
SOURCE: start button on the HMI won't work
There is a ribbon cable that connects to the control panel. Mine was operating the same as yours. I opened up the front and reinserted the cable and its been fine ever since. you need to take all the screws out from the door panel inside the washer to geet to it.
SOURCE: totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
SOURCE: My KitchenAid Superba won't run, no lights, nothing
turn off the power at the breaker and let it stay off for at least one hour
SOURCE: Turn key, nothing happens
It could be the park/neutral switch, next time it doesn't start try wiggling the shifter in park while turning the key, or shift to neutral and see if that will work. if that doesn't change the problem I would replace the ignition switch.
SOURCE: My built-in KitchenAid microwave/convection oven/oven
I have the same problem
any hints to solve it.
It's a 1988 vintage oven/microwave so I can't complain but it 's a pain if
I have to replace the unit
