MODE button, RADIO PRESETS,CLOCK,BASS All front buttons do not work
SOURCE: keep losing radio presets
Most current car head units requires two (2) kinds of B + supply; the yellow should be connected to an always on/constant B+12 such as the positive terminal of the battery. This is responsible for the memory and setting/configurations not to be erased when powered off. The red wire is connected to a switchable B+12 such as the ACC terminal of the IGN switch making the radio work only when the key is turned to ACC. Of course,the black is ocnnected to the chassis/ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: dewalt radio. no fm signal
did you try replacing AA abttery at the battery compartment.if it is still not working the display board is cappot
SOURCE: Set Radio Station Presets
Try just holding the button of choice down. In my Audi, when I had a factory head unit, to set for example, preset 2, I'd just tune to the station I wanted to program, and then hold down the number 2 preset button until the display stopped blinking. It was then preset.
SOURCE: radio and cigarette lighter outlet not working on 2003 matrix
There are 2 fuses that powers the radio, cigar lighter, etc.
They are: the 10 amp "GAUGE" and the 15 amp "CIG".
Look under the dash, on the driver side. The "CIG" fuse is the one that you need to replace.
It is in the middle of the fusebox, bottom row. again, a 15 amp fuse.
Please advise if you need additional information.
Hope this helps, and Thanks for choosing FixYa.
SOURCE: sharper image clock radio for shower
To set tuner presets:
1. Manually tune desired frequency.
2. Press MEMO button, Display will flash.
3. Manually enter memory position, 1-5.
4. Press MEMO button again.
The manual is available as a PDF file from the Grundig web site. Or, if you will e-mail me at deepblack <at>ugaalum<dot>uga<dot>edu and put "Yachtboy" in the subject, I will e-mail it to you
