Question about Bunn VPR Coffee Maker
I pour water in my Bunn VPR coffee maker and it does not come out of the sprayer.
Your coffee maker should have come with a 3/16 " spring that is tapered on both ends. unplug the coffee maker. unscrew the sprayer and insert the spring into the hole. push and turn the spring until it reaches the tank opening the line. after getting the line open you can run vinegar and water solution to help clear out calcium deposits.
Terrry
Posted on Jul 29, 2009
  • 4 Answers
You need to take it apart and clean it out. hard water is horrible on these machines. once every three to four months we clean ours. take the top off and you will see all the calcium deposits. need to clean it out. you can use CLR, just make sure you run the hell out of it before serving. you may need to let it sit over night once you get the majority of it out. after that you can run "brew-right" through it. just follow directions
I think my bunn-o-matic VPR needs cleaning and I do not have a manual for this machine. Can you advise on how to do this?
To clean the vpr you will need to take the lid off the machine. Be sure to unplug while doing this. First clean the water tray. You can unscrew the nut holding this tray and clean the tray in your sink. Put the tray back in and put the lid back on. Plug coffee maker in. Fill one coffee pot with vinegar and pour it in machine. After the water finishes coming out let the coffee maker sit overnight. Before you start filling the maker with water at least 6 times, be sure to clean the spray head. Make sure the 5 or 6 holes are free and clear of any build up. Then start with fresh water. Fill the coffee pot with fresh clean water and pour into machine. Let it finish and do this at least 6 times. If you can still taste or smell the vinegar repeat until you cant.
Mar 19, 2013 | Bunn Pour-O-Matic VPR
Poured water into the Bunn Coffee Maker Reservour is not heating the water.
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Thanks So Much, Mike
Aug 16, 2011 | Bunn VPR Coffee Maker
We have a Bunn vpr pot and we empty it in the fall and restart it in the summer. How much water needs to be added and how long do we wait until the water is ready? Also once we made a pot do we just need...
The bunn VPR is a gravity brew system what you put in if the tank is full is what you will get out. So pour water in until it flows out the sprayhead, then turn machine on, when it heats up fill up a carafe with water (1.9Liters) and put in your filter with water and brew. It is a good idea to pour water in every morning to make sure tank is full especially if you are not using brewer on the weekends.
Jun 26, 2011 | Bunn VPR Coffee Maker
The nurses use the Bunn VPR 2 burner coffee maker. They have succeeded in having horrible hard water residue all around the outside of the pour area. Vinegar doesn't seem to clean it off. What would...
This can be solved by running vinegar and water through unit and here is more information.
Jun 16, 2011 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
I have a Bunn VPR, it brews fine for a couple pots
Try running a quarter-pot 50/50 solution of white vinegar and cold water through to clean out calcium deposits in the pump system. Use a clean filter to catch the pumped debris. When pumped through, let cool somewhat, and reuse the cold mixture again twice more. Pour out the vinegar solution and run several cold water loads through to wash out the taste. Hope this helps!
May 24, 2010 | Bunn VPR Coffee Maker
Poured water into a Bunn Vpr coffee maker, the coffe was cold. Why did this happen?
Possible the hi-limit turned off the heater, the thermostat is not working or the elements are damaged, or the inline thermal fuse is damaged.
Nov 20, 2009 | Bunn VPR Coffee Maker
WE have the Bunn VPR series. It's a pourover
Hello this coffee maker has a one and a half gallon internal tank, could be one of a few problems, first thing to check is the spray head, unscrew this you may need some channel locks to get it off and check it..use a tooth pick to clear the 6 holes with any lime that may have formed...also if you use a commercial coffee company for your coffee they should have supplied you with a spring to clean the spray head tube. After checking these 2 items the next thing to check is there enough water in the tank..when the vpr is left on and not used for a few days the water in the tank evaporates..it takes approx two and a half pots of water to fill up the internal tank...try pouring another pot of water in...also turn machine off and take the 2 screws out of the top and see if there is lime blocking the drain hole in the fill pan. Hope this helps...please feel free to comment again if you have any other questions...Good Luck!!! Mike
Jul 14, 2009 | Bunn (VPRBUNN) 12-Cup Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Bunn VPR Coffee Maker Logo
305 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
