Question about Kyocera Copystar CS-1820 Black and White Copier
Initial set-up - Kyocera Copystar CS-1820 Black and White Copier
  • 143 Answers
Remove all the tape, install the toner cartridge enter 10871087 then 130 then "START"
Posted on Aug 03, 2009
How to disable demo mode lg 55ln5750
On remote Press SMART (with house symbol)
go to
settings then
option then
mode setting then select
home use
(and, if you're feeling really brave, but it's not necessary to do this to remove demo mode
to return to initial settings
SMART
Settings
OPTION
Initial Setting
Deletes all optional settings and returns to initial default mode.
Once initialization is complete, the TV will turn off and on by itself.
If Lock System is activated, a pop-up password prompt will appear.
Do not turn off the power during initialization)
Jun 27, 2014 | Tablets & eReaders
Tip
Virtual memory settings
Windows XP
1. Click Start, right-click My Computer, and then click Properties.
2. Click the Advanced tab. In the Performance section, click Settings.
3. Click the Advanced tab. In the Virtual memory section, click Change.
4. The hard disk drive that is used for virtual memory will usually be the
5. same disk drive that Windows is installed on. Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be approximately 200 MB in size but should be higher than or equal to the recommended paging file size as indicated in the lower section of the screen.
Once the initial size is set, Windows will reserve this amount of space on the hard disk drive for virtual memory and it will not be available to save information on.
The maximum amount allowable can be anything above the Initial size setting, but it is recommended that it be at least twice the Initial size setting
on Apr 27, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How to disable mode from lg 55 inch smart tv 55ln5750
You missed the word demo, why repost?
go to
settings then
option then
home use
SMART
Settings
OPTION
Initial Setting
Jun 27, 2014 | Televison & Video
How to clear back to factory setting
Service-mode functions
NVRAM initialization
An NVRAM initialization will return the following device settings to the factory-set defaults:
All menu settings, including the fax header and company name
Fax numbers and names that are associated with one-touch keys and speed-dial codes
Additionally, all faxes stored in memory are cleared.
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
When the NVRAM initialization process finishes, the product control panel shows the Ready message.
Super NVRAM initialization
The super NVRAM initialization clears all settings affected by a regular NVRAM initialization, and also
clears the product language and country/region settings. Both settings must be reset after a super
NVRAM initialization.
When the process finishes, the product control panel shows the Ready message.
Apr 18, 2013 | HP LaserJet M1522nf Multifunction Printer...
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
How do you restore to factory settings my sony cybershot dsc t700?
Sony call this initialize.
It is on the menu under Home -> Settings -> Main Settings -> Initialize ->
The Manual has notes about this:
The Password Lock is not released even if you initialize the settings.
Be sure not to turn off the camera while initializing.
I found this in the manual, page 59 at:
http://pdf.crse.com/manuals/4000946111.pdf
Hope this helps.
Feb 03, 2010 | Sony Cyber-shot DSC-T700 Digital Camera
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
I cant set the clock on my pioneer deh 21001b cd player
Adjusting initial settings
1 Press SRC/OFF and hold until the unit
turns off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
2 Press MULTI-CONTROL to display the
setting mode.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
Initial set up of PS3. initial set up screen not displayed
When tv and ps3 backswitch turned on hold down the front power button when off until the ps3 has done a double beep after the intitial beep and wait for a max of 1 min and initial set up screen should appear
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Copy memory on HP L7580
sounds like you need to change your virtual memory settings or buy more RAM.
Here is how to change the settings:
I am assuming you use WINXP
  1. Click Start , right-click My Computer , and then click Properties .
  3. In the Performance section, click Settings .
  4. Click the Advanced tab.
  5. In the Virtual memory section, click Change . Both the Initial and Maximum settings should be less than the reported Space available on the hard disk drive. The Initial size setting for the virtual memory settings should be about 200 MB, and should be higher than or equal to the recommended paging file size shown in the lower section of the dialog box. When you set the initial size, Windows reserves on the hard disk drive the amount of space you designated for virtual memory. The maximum amount allowable can be anything above the Initial size setting, but it should be at least twice the Initial size setting, as shown in Figure 2. Figure 2: The Windows XP Virtual Memory settings c00174885.gif
  6. Based on the information above, make any necessary changes to the Initial size and Maximum size settings.
  7. Click Set , and then click OK .
Sep 05, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
Kyocera Copystar CS-1820 Black and White Copier Logo
77 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
