Air conditioner keeps beeping, it is almost constantly.
SOURCE: I have a frigidaire window air conditioner
I assume that you are speaking of the high pressure cut-out switch, (usually has a red button) if that is the switch then you need to remove the unit from the window, take it to the car wash and clean the condenser coil. If you are speaking about the GFCI located in the cord, it could be the cord itself or you have a componenet shorted to ground tha needs repair
SOURCE: Remove Front panel for cleaning
Need a part number for a "drain pipe" that would fit in the bottom of the drain pan so I can redirect condensate for Frigidaire Air Conditioner, model FAS257Q2A
I appreciate your post, Tamara Brazile!
I see that your sleep button on your Frigidaire air conditioner continues to beep. Do you see any error codes on your air conditioner? Additionally, could you please provide me with your model number? You can locate the serial tag (which lists your model number) on the outside frame of your air conditioner or under the front panel. With that additional information I can further assist you. -Matt
