Question about Rancilio (RAROCKYND) Grinder
In which direction do you turn the barrel to make finer coffee?
  • 1,089 Answers
HI
Clockwise is the direction for making the grind finer, but make sure that the machine is running at the time you turn the hopper. If its not running, you trap beans under the burrs and jam the motor, which could do damage. There are numbers on the bottom of the hopper, but they are just a reference to go by.
Posted on Jul 29, 2009
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Why won't my solis 5000 grinder turn to produce a finer grind coffee?
Have to turn it while it is grinding. Don't force it or it will break.
Jun 04, 2014 | Solis Master 5000 Espresso Machine
COFFEE COMES OUT TOO FAST
Try making your coffee a finer grind. The finer the grind of the beans, the slower the water will flow through the beans. Also fresher beans will make the water flow slower due to the moisture and oil content in the beans.
Jan 07, 2014 | Starbucks Saeco Italia Digital Barista...
My gaggia titanium is dispensing very weak coffee. No idea why. Have tried different beans. No change.
try a finer grind coffee , you cant use a "store" grind in a cappuccino machine it requires a much finer grind than that
Dec 07, 2011 | Gaggia Titanium Espresso Machine
Too coarse a grind
have you tried adjusting anti-clockwise whilst grinder is in operation ?
Nov 11, 2011 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Trying to figure out which direction to turn the knob inside the coffee bean grinder to make my coffee weaker. Others have told me that the finer the grinds, the stronger the coffee. And the courser the...
HI
You can run more water through the same grind you are using now or you can trun the big knob in the bean hopper to a larger #. That will make the grind coarser. You can turn the knob to a larger # anytime but to turn it to a smaller # it has to be grinding or you will damage the grinder. If you have 2 knobs in the bean hopper, you can turn the small knob down towards the -(minus) and reduce the amount of coffee in the brew unit.
Apr 17, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
How do I adjust the grinder to make the coffee grind finer? ie. the coffee is pouring way too fast and giving no crema.
Depending on the model and make on the grinder you just have to turn the adjustment collar clockwise for finer, that is the case with most grinders.
Nov 11, 2009 | Coffee Makers & Espresso Machines
Flow through head too fast. Coffee packed very tight and ground fine
Try grinding coffee finer.
Check the shower screen to make sure that there is no damage to it, you can use an 8mm wrench or a small flat screwdriver to remove the screen.
Is the coffee fresh ground(within a few days, 2 at the most).
Jun 10, 2009 | Rancilio Silvia Espresso Machine
Can I adjust the water flow for finely ground coffee?
You probably have coffee ground for a drip coffee pot, not an automatic drip coffee maker. With a drip coffee pot, you put the coffee in and add the hot water on top of that. You might want to try a coffee press. They are fantastic for the finer grinds of coffee. Some Mexican coffees are ground almost as fine as flour and a press works great. You can get a press for about $12 & up.
Jan 30, 2009 | Cuisinart DCC-1200 Coffee Maker
Rancilio (RAROCKYND) Grinder Logo
116 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
