Question about Zanussi 24 in. ZSF6120 Free-standing Dishwasher
Problems! zanussi zsf6120
I have a zanussi zsf 6120 and the thing works perfect but just doesn't get hot water to wash with and doesn't try? any suggestions? thermostat heating element??
    New Friend:
  • 67 Answers
Re: problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Posted on Nov 30, 2007
0 characters
3 Points
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
Dishwasher zanussi zsf 6128
Either it's not getting enough water to flip over to the next part of it's cycle (unlikely) or the water float gauge is not working properly.
When the dishwasher is cool, look for the float inside the dishwasher --usually a small plastic dome or cylinder mounted inside at the tub's base, near the front. When you move most types of floats up and down, you can hear them click because they trip a lever (they are spring loaded). Lift out the float mechanism and clean around the float tube; many floats must be disconnected from below--to do this you'll have to remove the lower access panel. Rinse off the float, then replace it in the tube and be sure it moves up and down freely.
If you're experienced with minor repair work shut off the hot water valve to the appliance. Locate the water intake valve, behind the dishwasher's bottom front panel, disassemble the valve to reveal the screen, clean debris from the screen, and reassemble. If the screen doesn't appear to be blocked, call a repairperson (they will probably need to replace the water intake valve).
If none of this helps, call a repair person. Any of several parts, including water inlet valve, pressure switch, and the timer or selector switch, may be faulty.
Mar 02, 2008 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Zanussi dishwasher water input
it is possible but if you use a hot fill you will find that the rinse aid will produce a large amount of foam and the dishes wont dry properly
Dec 22, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Dishwasher doesn't run
If you turn on the dishwasher and nothing happens:
1) Be sure the power is on, the door is latched, and the control is turned on. Also make sure the appliance cord is plugged into the electrical receptacle under the sink (some are hardwired and don't come unplugged).
2) If that doesn't solve the problem, the door switch, the timer, or the selector switch may be defective. To solve the problem, you may be able to adjust the door latch's strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it).
3) If that doesn't work, call an appliance repairperson.
Dec 02, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
No heat
You should check for 115/220v on heater tags, In case you don't have it, your problem is a malfunction thermostat that should be replaced. Good luck!
Dec 06, 2006 | Zanussi 24 in. ZSF6120 Free-standing...
Zanussi 24 in. ZSF6120 Free-standing Dishwasher Logo
665 people viewed this question
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
