SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
[email protected] for more info.
SOURCE: having problem disengaging child proof locks
There is a switch on the door along the surface that curves to seal with the body. That switch will put it in and out of safty lock. There should be a decal there that will tell you which way. Hope this helpsl
SOURCE: LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
SOURCE: lg washer model no wd
How to get the door open:
Thread a shoelace between the door and the front of the machine from the top, over the latch on the middle right and to the bottom. Pull both ends of the shoelace towards the hinge on the left and this will manually pull open the latch with NO DAMAGE. Once open you can access the screws to remove the mechanism and simply buy a replacement.
LG, bloody hopeless support and no simple way to rectify this problem in the manual when it's so easy once you know.
SOURCE: mHOW UNLOCK THE CHILD LOCK
The "CL" code is not an error! This means "Child Lock"!
To unlock the washing machine you will press and holding within 3-5 sec two button, marked "child lock if you have any further questions message me back or this solution does not work message me back the make and model of your machine and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
