Question about Technics SL-1210 Turntable
Hissy and distorted
Hello, I am looking for a bit of advise, i purchased 2nd hand decks, one which is perfect.
The other one plays some records perfect, but others are very bassy / hissy / distorted.
I changed the needles and its still happening.
Any idea what the issue could be?
  • 515 Answers
On the 1200s, there really isn't anything that would cause such an issue unless you have a bad tonearm, or faulty RCA cables. If you've isolated the issue to the unit, and not the cartridges/styli/headshells, then the only next course of action is to have your RCA cables replace, and if the problem persists, the only other faulty part would be the tonearm. You can purchase parts for your 1200 HERE, however, soldering skills will be required if you are going to attempt to do this yourself. Also, a word of caution, the Tonearm is not easy to replace, so you might need professional assistance with this one.
Also, if you can ask the previous owner if any work was done on the units, perhaps it was a self-repair, and was not done correctly, causing these issues.
Posted on Nov 23, 2007
Sony DAV-DZ560 Can I use a record deck and put it through the surround sound to play vinyl's
Shouldn't be a problem as long as you get a record player with a built-in preamp. Old record players did not have a preamp, and will not output a signal at a high enough level to be used through the sony system.
Jan 10, 2013 | Audio Players & Recorders
I have just bought a new LG 42LM620T TV. The picture is fine but every so often the sound is a little distorted. It's as though the sound has been recorded at too high a level for the speakers. It
No doubt in the audio menu for your TV there are several tweaks available in there - maybe even a graphic equalizer and perhaps other potential modifications. Access the audio menu with your remote and play around in there. You may be able to soften the audio up a bit. Good luck.
Jul 26, 2017 | Televison & Video
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Mar 24, 2012 | Audio Players & Recorders
All is fine with this turntable eccept for the fact that when the sound comes through the speakers you can make out the track but the sound is distorted.
You don't say whether you have only just acquired this deck or if you have been using it for some time and it has only now started to give problems.
There are 2 or 3 possible explanations.
  1. If you have only just got this deck and are using it on a stereo that has a dedicated phono (record player) input it may be that you need to get inside your turntable to turn off the built in pre-amplifier switch. To do so make sure the tone arm is securely fixed into it's holder (a rubber band will hold it in tightly) before turning the deck upside down and unscrewing the bottom.
  2. If you have just got this deck and are trying to play it through a stereo system that does NOT have a dedicated phono (record player) input you may need to get inside the deck to turn the phono pre-amplifier switch on.
  3. And if the deck has been used for some time this is the most likely - the record stylus (needle) probably needs replacing. Personally, although it is a bit more expensive, I prefer to replace the whole cartridge rather than just the stylus as they do need changing from time to time anyway. Always replace the stylus at least at the frequency recommended by the manufacturer. Regularly clean the stylus with very gentle strokes from the back towards the front using a small soft brush.
Feb 02, 2011 | Aiwa PX-E860 Turntable
Hello What is the difference between the recording NR switch b/off/ c
If you record a track with NR (standing for Noise Reduction) on it will sound brighter than with it off. The B and C sounds like it's Dolby B and Dolby C type noise reduction. C is better than B, but it's up to you to decide which you like best. Both systems were developed to deal with the problem of tape hiss. Most commercial tapes use Dolby B. If you record with either Dolby on it is best to play it back with it on, as it can make the tape sound more hissy, switched off. But if you don't record with it on, then putting Dolby on to playback would make it sound dull.
Sep 24, 2010 | Pioneer CT-W404R Single Cassette Deck
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
No Disc Error
there is no fix you bought someone else's junk
May 08, 2017 | The Singing Machine DVD/CDG Karaoke System...
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
Technics SL-1210 Turntable Logo
78 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
