Question about Seagate (ST380011A) 80 GB IDE Hard Drive
I have a 320 gb ide seagate external hard disk which i connect to my laptop through power .it is showing drive corrupt.how do i repair it
  • 1 more comment
  • ruchikachiki Jul 30, 2009
    yes i m using external casing .
    thanks for check disk but I had tried it didnt work :(
  • Are you using any external casing for your harddisk ?
  • 590 Answers
Download Norton disk doctor from their website and run it. Most of the problems with partitions, boot sectors ( soft defects) will be fixed automatically.
Posted on Jul 30, 2009
    President:
  • 627 Answers
Run the checkdisk utility to repair corrupt volume
start - run - chkdsk drive_name /f /r
e.g. chkdsk e: /f /r
Posted on Jul 29, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate 9sd2a3-500 320 GB Problem
Improve the Fixya experience for everyone by voting!
It sounds as though you have one of the following problems:
  1. Dirty contacts that can be cleaned with CRC electronic component cleaner;
  2. A faulty drive that may have been dropped at some point in time. Your drive may have a three-year warranty and Seagate will replace it. Just go online and provide the serial number; and.
  3. You may have to reinstall the drivers. The Seagate website can provide this if needed.
Apr 14, 2012 | Seagate 320GB Portable External Drive ...
My Seagate portable 320gb external hard drive fell on the floor now my computer and laptop don't see it( won't let me get in to the hard drive) , how do I fix this , Important files on it Help please
Since this external hard drive is USB powered and felt on the floor, you could have a broken USB connector or interface card, both located inside hard disk case, you should contact Seagate technical support or repair service, or if you have electronics skills, you could open and check hardware by yourself.
Feb 18, 2011 | Seagate 320GB Portable External Drive ...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
How can i make my seagate hard disk an usb hard
It is quite easy, do not worry.
You only need to bought and USB enclosure, here is a link to many products on ebay
http://search.ebay.com/search/search.dll?from=R40&_trksid=p0.m37.l1313&satitle=hard+drive+enclosure+usb&category0=
then you have to connect your hard drive inside the enclosure and the enclosure to your computer using the usb cable and that's it.
Just be carefull about the enclosure, I guess it is a Hard drive from a desktop, is in it? because some enclosure are for laptop's hard drive.
Also you need to know if your hard drive is SATA or IDE, IDE is the normal gray bus cable with fourty some pins, and the SATA it is a really small cable (I do not use technicims to not confuse you even more).
Also, there are some adapters from IDE/SATA to USB that you can buy in your local computer store (do not go to bestbuy, compusa, ... they only sell external hd), or also get it from ebay.
The only diference between the enclosure and the adapter is that the enclosure looks better :D, and the adapter is just a bunch of cables.
Mar 19, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
HARD DISK CAPACITY PROBLEM
When your hard disk capacity says 320, that does not mean 320 GB fo free space, Total capacity is 320 GB, from this space required for the partition table, boot sector, etc will be taken, Dont worry only the available free space will be shown.
This is not a problem, so dont worry.
Dont forget to rate me fixya
Jan 10, 2008 | Computers & Internet
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate (ST380011A) 80 GB IDE Hard Drive Logo
128 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
