Question about Ovens
Creda cooker grill not working,elements replaced, still not working. any suggestions?
  • Ovens Master
  • 3,463 Answers
Could possibly be grill selector switch faulty, or, depending on the model, it is sometimes caused by a faulty main oven door switch.
Please rate my solution.
Thanks.
Posted on Jul 29, 2009
2 Suggested Answers
blackmar
  • 235 Answers
SOURCE: Creda Concept Solarglo Cooker. Grill
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Posted on Feb 12, 2011
Testimonial: "Many thanks for the prompt reply. I'll follow up your recommendation!"
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
The main oven doesn't heat but the main oven grill function does heat up! I'm not sure if this means the element is no longer working or if it is a problem with the control switch?
Make sure the power is off, then there should be two screws holding the element to the back wall remove them. Pull the element out until you can get to the wires, sometimes a wire will burn off at the connector, if that's the case replace it with a high temp connector if not disconnect both wires and do a continuity check on the element
Apr 14, 2015 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Feb 11, 2011 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Sep 03, 2009 | Ovens
Top oven on creda electric cooker working but bottom one is not have continuity through element and fan is working
Even though you have continuity trhrough the element, it could still be faulty, to be sure if the element is o/k or not, you need to check if it is getting 240 volts to it.
If it is, and it is not getting hot, then you need to replace it.
Thanks.
Jul 18, 2009 | Ovens
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Ovens Logo
323 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
