Question about GE Washing Machines
Have model # wbvh5100hww - load machine - door is locked - hit start. hear click. tumbler turns a bit in each direction but machine does not start
  • 1 more comment
  • mnathan719 Jul 30, 2009
    The machine does not take in water. Water never comes in. What I descrbed is from the very begining. By load machine I meant putting the clothing in for wash.
    The machine does not fill with water. What I described in from the very begining of trying to do a wash. Thank you
    It made sense to me. I will have to wait for the warranty service repairman. I was hoping it was a simple thing. Thank you.
  • 15,935 Answers
You will have to determine if the timer is faulty - or if the inlet (mixer) valve is getting the signal from the timer - but just not energizing the solenoid to allow water in.... or the pressure switch has failed - that the controller thinks there is water in the tub and will not spin for safety reasons.
CLICK HERE to see the Controler/Timer
CLICK HERE to see the Mixer Valve. #203 in THIS DIAGRAM
The last possibility is a faulty Pressure Switch - so that the timer is sent a signal there is water in the tub.
CLICK HERE to see the switch
You will need to determine which part is faulty - then return for a re-post if you have additional questions.
Please accept this answer to remove it from the work queue.
Posted on Jul 30, 2009
    Genius:
  • 1,341 Answers
I assume that this machine is taking water and then does not complete its wash..Now if this is so then you need to replace the pcb or now if tumbler did not turn at all then you should check the belt(if it's belt driven) as these are quite usual and first thing that goes wrong.Be careful here as pcb cost a lot and if you are no expert at this then work out the cost of a repair man and total it up..Sometimes you are better off buying a new one..Now it all depends on your location and labour cost..
Posted on Jul 29, 2009
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
GE WBVH5100HWW front load washer stops at 1
It appears that you have an electronic control board (directly behind the touchpad) issue. Contact an appliance service company.
Apr 13, 2010 | GE Washing Machines
During the spin cycle, the agitator makes a knocking/clicking sounds. Works good other then that.
If your machine type is a FAV6800AW or FAV9800AW the tumblers or agitator should no rotate in spin cycle maybe a 1/8 turn and no more at the start of spin cycle . If your machine is one of the above machine types maybe you have coins or something under the tumblers. You can remove the tumblers by removing the plastic tumbler caps and with a #20 torx driver. See page 37 for tumbler removal. If your machine type is not the above please disregard my post.
The Service Manual for reference. Sears Parts Direct for reference.
I have another thought but if you could confirm the machine model number that would be helpful. So many folks post non FAV6800AW machine types in this forum.
Thank you… Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
WHEN FIRST STARTING WASHER THE DOOR LOCKS THE DRUM STARTS TO SPIN THEN STOPS AND THE DOOR UNLOCKS
you may have to unplug unit and plug it back in. If not working board may need to be replaced
Apr 07, 2009 | General Electric WBVH5100HWW Front Load...
Dryer, gas model #ddgg57806clad stopped working after it finished the first load of the day. It doesn't feel like it's totally connected. The timer clicks, but it doesn't feel like there's power going to...
Hi, I'm posting my own solution to my problem. Thank you fixya and the many people who had a similar problem who sent in solutions to others on this site.
The door switch to the dryer was hitting a worn out area of the gasket surrounding the door and prevented a connection to the tumbler. After manually checking the tumbler to make sure it wasn't stuck, I temporarily put a piece of masking tape over the switch with the door open. Then I turned the timer knob on while the door was open to see if the dryer started and voila! it started. Hope this solution helps someone else. Iris
Mar 07, 2009 | GE Dryers
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Nov 12, 2008 | GE WBVH6240F Front Load Washer
Door Lock does not lock
1 o 2 issues either a bad door lock, or the machine control board located under the main top is malfunctioning.
Feb 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
Washing Machines Logo
21 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
