I have an A.O. Smith f48l47a50 blower motor, and I need help with wiring. First it's a 460v,1phase,1/2hp,975rpm,3spd motor. My question with the wiring is do I need to supply a wire for line power? I know the brown and purple go to the capacitor. The green is ground. I guessing the blue and orange are to designate low/med speed, but that's all the wires that are attatched. I think I need to supply a wire from the blower motor relay to the motor's hi spd terminal. Could you confirm this?
  • steelhead20 Jul 30, 2009
    dmftrucker- Yes, it's definitly a 460, 1 phase motor. The RTU itself is a 3-phase, but the supply and condenser fan motors are 1 phase.
  • t1m130
    t1m130 May 11, 2010
    what brand/model furnace are you installing this in ? is this an exact replacement from the one that went bad?
    President:
  • 1,922 Answers
Are you SURE its 460volt single phase??? that voltage is normally a 3phase motor voltage,and color of wires is right for 480/277, but that would be 3 phase.....not saying your wrong,just make sure
Posted on Jul 30, 2009
  • daniel  hendrickson
    daniel hendrickson Jul 30, 2009
    hi again youre right, go to aosmith website maybe they can give you some input or the maker of the unit its installed on...sorry
Wiring a ge motor 220; has three black wires
That's a 3 phase motor(ph3). And probably a 220v/460v? Or a 110v/220v, BIG difference! You'll need to figure out your supply voltage and wire it accordingly. Normally, if 220/460, all 3 black wires are hot legs, and this is probably what you have, because 110v will normally have higher amperage than what you posted. And if the motor runs backwards, switch any leg with 1 other. Hope this helps!
Aug 19, 2017 | GE Heating & Cooling
Need help wiring a 5HP 1Phase motor on Powermatic 66
As you only have 4 wires from the motor it should be straight forward as two would be from the start winding (Black and red) and the other the run winding (White with yellow stripe and Blue). You should be able to check this with a tester as there should only be continuity between the wires as mentioned above.
Reference the thermal switch, I am not 100% sure on the color codes but have attached a diagram which should help but will advise as best as I can on the connection. The diagram is for a high/low voltage but you can disregard the winding on 3 and 4 but should help on the understanding.
Join the blue and black wire from the motor together and connect to the black wire from the supply. You should be able to run the motor (Excluding the thermal switch) by connecting the White with yellow stripe and the red wire together along with the white from the supply. To include this switch I would presume that you would connect the red wire from the motor to the brown wire from the thermal switch, the yellow wire from thermal switch to the White with yellow stripe from the motor and finally the white wire from the thermal switch to the white from the supply.
Jan 29, 2014 | Powermatic Saws
Need to change a broken blower motor in RUUD central air unit. Old central air blower motor (GE electric) was connected with brown and orange wire to 15 MHD capacitor. Another orange wire from central air...
on the motor should be a diagram detailing the wires. brown white goes to either side of the capacitor and brown wire to other side of capacitor. hi speed goes to normally open contact on the indoor fan relay and the wire designated common on the motor goes to the other side of power from the relay contacts.
Oct 03, 2012 | Heating & Cooling
What transmission will interchange with mine? 1995 silverado 3/4 ton 4x4
There is alot of transmissions that will bolt to your motor 4L80e 4spd, 4L60e 4spd, th400 3spd, th350 3spd, th200 3spd, 700R4 4spd and power glide 2spd. But you are going to have to either shorten or lengthen your drive shaft and move you cross member. If your going from 3spd to 4spd you mite need to change speedo cable.
Feb 22, 2011 | 1995 Chevrolet Silverado 2500
Need som help with a wiring question on a CD#52 AO Smith 1/2 hp blower motor. the furnace runs wiring for a white, red and black not sure which wires go where.
Look at the schematic on the inside panel of the cover you removed. It should have the schematic with the wires and colors labeled as to what goes where. The wires are a common, run and start wire. They schematic should identify the wire by color and motor connection by number. You should be able to see the numbers on the motor by the connection. hope this helps.
Jan 29, 2011 | Heating & Cooling
What do wire colors mean for ao smith dl1056 blower motor
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 31, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
or
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
