Question about Konica Minolta magicolor 2400 Laser Printer
Paper jam at transfer roller 2400z - Konica Minolta magicolor 2400 Laser Printer
    Guru:
  • 1,894 Answers
This link must help you
thank you
Posted on Jul 29, 2009
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Paper Jam error
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure thatyou have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
May 17, 2008 | Olympus P-440 Thermal Photo Printer
Tip
Attention To Solve Paper James Of Transfer Roller
Sometimes you may be able to solve the common problems yourself in your laser printer if you know a little about the structure inside it, such as paper jams due to improper positioning at the transfer roller. Before the printing process at the fuser assembly, the paper has to pass through the transfer roller inside a laser printer that is used for transferring toner from the cartridge drum onto the printing medium. It works with opposing electrical charges to pull the toner particles.
Paper jams usually occur at the image transferring process, if the paper get stuck at the transfer roller, just open up the side cover and pull out the paper gently, don't touch roller surface without gloves when hold the ends of the roller, as the sweat and oil of your hand can pollute and damage the surface material.
on May 05, 2017 | Office Equipment & Supplies
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Fuzzy prints, paper jam
If you would like the service manual reply with your email address (it's 5.87mb).
Your first problem could be caused by one of the following, feed roller from the paper tray is slipping making the paper to leave the tray late causing the registration sensor to flag an error because it hasn't detected the paper quick enough or the registration sensor is just not working, could even be the paper feed clutch or registration clutch. I don't think the problem is with the thin rollers.
The second problem could be a few things, possibly a consumable, i would start by swapping the consumables over between the two machines, transfer unit, transfer roller, cleaning roller, photo developers, fuser etc, if that doesn't cure the fault clean the hv connections. This problem is related to the high voltage so investigate in that area.
Sorry for being long winded, but without being in front of your printers its a bit of a guessing game.
Apr 08, 2009 | Lexmark C510 Laser Printer
Canon PC-860 Black & White
ERROR MESSAGE ON MY CANON D 860 COPIER
Jan 30, 2008 | Canon PC-860 Black and White Copier
Konica Minolta magicolor 2400 Laser Printer Logo
171 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
