Question about Refrigerators
Ice maker will not fill with water and make ice. A repair man replaced the ice maker and the unit worked for about 1 week. I worked on the ice maker and got it working, but for only about 1 week. I need a schedmatic to trace out the wiring.
  • 24 Answers
In my GE side-by-side there is a parts diagram/schematic folded up inside the control knob housing (inside the fresh food compartment).
Posted on Jul 29, 2009
Ice-maker not functioning
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
May 29, 2011 | KitchenAid Refrigerator
My freezer compartment is making a loud vibrating noise. The ice maker is not working, the water freezes on the inlet ramp to the cube maker. What gives?
The vibration is usually an unballance, check the freezer fan blade for any broken pieces. The water freeze will cause the Ice maker to not work..if the fill valve for the ice maker leaks, even a small bit it will freeze up on that "inlet ramp" if so, replace the fill valve. Else, I've found a unit not used, left alone for a week or more.. that tube still freezes up...gets too cold?
Oct 24, 2009 | Frigidaire Refrigerators
Have a Maytag side by side with ice maker...it quit making ice within 3 months of installation. Had one repair man look at it...said that it was a common problem w/ Maytag...hit ice maker with his fist a...
Assuming it's not still under warranty, I would probably replace the icemaker components inside the freezer.
The repairman's "fix" indicates that there is some kind of problem with the "brains" of the icemaker. It would probably not be cost effective to try to diagnose and fix the problem.
Oct 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
I have a side by side refrigerator that is 5 years old, and the ice maker does not work. We purchased a 5 year warrenty from Best Buy and requested warrenty repair. It took 3 weeks to get the repair part...
The ice makers are rather finiky. limit switches for almost every movement. Sounds excessive, but replacing the ice maker module will save you a lot of worries. The signal to fill with water comes from the icemaker when it is in the correct position
Sep 14, 2009 | Refrigerators
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
My Maytag MZD2766GES is not filling the ice maker.
there is a test button underneath the ice maker press this making sure you put a tray of some kind underneath this will operate the icemaker and go through its empty and fill cycle ,if it does not fill it will be the solonoid valve
Jun 27, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker doesn't work!
Could be the sensor for the ice maker to fill up....we have a wire bar that flips up when full so it shuts off ....also a piece of ice gets stuck in the plastic fingers somtimes but since you defrosted it that shouldn't be the problem....not sure if you can take the ice maker out yourself ...better call the repair man ...
Jan 12, 2009 | Whirlpool Refrigerators
ICE MAKER
TWO THINGS YOU NEED TO CHECK.IS YOUR WATER VALVE WORKING TO ALLOW THE APPLIANCE TO TAKE IN WATER.AND IS THE ICE MAKER WORKING PROPERLY AND SENDING INFORMATION TO THE VALVE TO ALLOW WATER IN TO THE ICE MAKER.GOOD LUCK.MOHAMED
Sep 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice Maker? Control Panel?
ARE the dispensing?? your post says yes but if not the 1st thing is to check to see if the water is turned on.. also the valve in the rear of the unit maybe bad let me know
Oct 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
117 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
