SOURCE: No Disc
Hello Kenny,
My name is David thank you for using FixYa.com for your answer.
Sounds to me that the eye is dirty or even bad try to run a dvd cleaning disk
In your player you can get them in most all stores such as walmart etc...
try to run it in the machine if it is real dirty you may have to run it a few times
if that doesnt help you can try to do it manually by taking the cover off
your player and then opening the dvd compartment to expose the eye and clean it with a cue tip
and alcohol lightly dip the cue tip and clean the lense off I have had to do that with dvd players and old playstations in the past and it worked fine. try the disk first though before taking anything apart
good luck this should work for you.
Thank you again for choosing FixYa.com for all your answers and please feel free to rate me for the answer i have provided.
SOURCE: dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
SOURCE: disc loads, makes click click sound then message no disc
that click click is the laser trying to focus and it is hitting the disc.
the biggest failure is the disc motors.they are very tiny motors and if they do not spin fast enough,the laser can not get the info it needs.
sometimes banging on it lightly while it is focusing will get the disc to spin.
with the price of new ones,it is not worth repair.
that is why i got out of the repair biz in 1995
SOURCE: samsung DVD player when disc put in after trying
it can be two possibilities. 1)either the disk is faulty.check out in another player or drive and confirm whether the disk is properly working. 2)or the lens in the drive which reads the disk is either faulty or got dusty.in the electronics shop you get lens cleaning cd.insert that in your drive and play it.it will spin for a period of time and stop.then insert your dvd disk and check out if the same problem.then drive inner lens is faulty and needs replacement.
