What you called the hardware that can connect my system unit to my television?
    Sergeant:
  • 173 Answers
It is TV tunner card.
Posted on Jul 29, 2009
    Brigadier General:
  • 4,090 Answers
Heres a link to watch so you can do that.
http://www.youtube.com/watch?v=eWRzYMsNEZM
I was wondering how to download music onto my eclipse for kids. I am going on a trip with my kid.
    1)Connect the MP3 player to a working USB port.
    2)When the unit is connected to computer, it will create a gray and green icon in the system tray (lower right hand of desktop). The icon will be called safely remove hardware.
    3)Go to the "my computer" section of computer. In there you will find a section called "devices with removable storage"
    4)Locate drive created by unit, generally called removable disk, with a letter in parenthesis.
    5)Open drive by either double left clicking on drive itself, or by right clicking to open option menu then left click on desired drive.
    6)Locate music stored on computer.
    7)Click on song itself and right click and click copy. Open removable disk, right click on empty space, and select paste.
    8)Repeat step 7 for as many songs as you need
Nov 01, 2015 | Eclipse Audio Players & Recorders
Philips HTS3154 Theater System. The redlight by the standby button flashes on/off continuously and depressing the standby button will not get the machine to turn on. Like wise the remote control will not...
Your Home Theater has problem in Amp section. Please check speaker wires are connected properly and see its insulation as well. If found fine, Amp Output in Home Theater is bad.
Aug 15, 2008 | Philips Televison & Video
Connecting my VCR/DVD combo to Toshiba television
It would be helpful to know what cable your trying to connect, component, S-VIDEO, HDMI, etc. Also the make & model of the combo unit & Toshiba TV. However the basic process is usually the same for most hardware. Make sure the connection to combo unit is "video/audio out" not in and make sure the input for the TV says IN not OUT. Then you need to set the TV to the correct input channel. And then make sure the combo unit is using the correct output... usually this is automatic for component cables but not always.
Nov 16, 2011 | Toshiba Televison & Video
How can I connect a 5.1 sound system to a sharp
Sharp televisions don't work like you need them to when connecting them to a 5.1 sound system. You can connect them with a fiber optic cable from their digital audio out to the sound system's digital audio in BUT when you turn everything on no sound comes out of the sound system. So you start checking connections and troubleshooting, call Sharp, and maybe even call the sound system manufacturer. You may get a customer service representative knowledgeable enough to explain to you that Sharp televisions were designed without center channel capability. This means that the only use for the digital audio out is to get sound from your sound system when watching tv channels when your Sharp television is connected to your rooftop antenna only or directly to basic digital cable with no cable box or satellite tv receiver. Yes I just stated that you only connect the sound system to the Sharp television when you are watching over the air broadcasts or basic digital cable without a cable box.
People say "but that doesn't make any sense." But it is true. Sometimes you will get lucky and connect a Sharp television to the sound system with the fiber optic cable and get sound out of one of the devices you've connected to the Sharp television with an hdmi cable. You will then be directed by the customer service rep to connect all your devices to the sound system and connect them all to the television as well OR connect all your devices to the sound system with hdmi cables and connect the sound system to the television with one hdmi cable.
Jul 19, 2011 | Sharp LC40E77U LCD TV
Driver
In computing, a device driver is a computer program allowing higher-level computer programs to interact with a hardware device.
A driver typically communicates with the device through the computer bus or communications subsystem to which the hardware connects. When a calling program invokes a routine in the driver, the driver issues commands to the device. Once the device sends data back to the driver, the driver may invoke routines in the original calling program. Drivers are hardware-dependent and operating-system-specific. They usually provide the interrupt handling required for any necessary asynchronous time-dependent hardware interface.
Jun 26, 2011 | Computers & Internet
Hi am trying to connect it with my pc but its asking new hardware found "mtp device driver" but not installing just poping up againg and again not connecting with pc
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
gylacz
May 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
Remove hardware
OK follow this steps properly. 1. Turn of you PC and Unplug it from 220ACV. 2. Unscrew your system unit chasing. 3. Inside the system unit there's a 7.5 inch flat form hardware or that's what we call the Hard Disk. 4. Unplug the IDE or the SATA cable from the Motherboard. 5. Unplug also the power supply connector from your Hard Disk. 6. Unscrew the 7.5 inch flat form hardware or the Hard Disk. 7. Your Done. God Speed. I hope this steps will help you.
Apr 11, 2010 | Acer Aspire T690 (AST690UP820A) PC...
Blue screen saying stop: oxoooooo24(0x00190203................ cant start in any safe mode
the blue color screen display is within the system or hardware conflict which commonly called fatal error. The best way to correct the problem is to re-install the OS. Your system is corrupted due to system or hardware conflict. Or before doing the re-installation of OS, pls try to remove the memory and have the memory pins clean using a pencil eraser or any eraser available eraser you have. Then install the memory to the slot and power ON your unit. If the same happens in your unit then you need to reformat/reinstall your OS. thanks
Feb 08, 2010 | HP Pavilion zd8000 Notebook
I have the linksys wrt110 router hooked up and there is internet flowing into it but not to my laptop wireless, it doesnt even work when i have the ethernet cord running from it ot my laptop
re-install the software , if you don't have it goto Linksys . com
these units do a funny thing when you are not looking they reset themselves , the hardware on your computer will also have to be
reset , goto control panel/systems/hardware/device manager
click on device uninstall your Ethernet device and reboot the
computer , next place the CD into the tray and start over , I use
the same unit as you , mine has had to be reinstalled 3 times so
far check all connection locations , if all else fails call Linksys
Feb 05, 2010 | Linksys WRT110 Wireless Router
Xbox 360 Ethernet Connection broken
sometimes you cant run you will need to adjust your network settings call 1-800 4 myxbox they can help
Sep 15, 2008 | Microsoft Xbox 360 Console
Televison & Video Logo
Top Televison & Video Experts
