I am sorry but i failed to mention the hp l1706 monitor i have makes a hissing noise when on thank you to ghasson for answer but maybe you could help again
    Brigadier General:
  • 4,090 Answers
A hissing sound from a monitor if its not coming from internal speakers but inside the case, try looking through the air vents with the lights turned out and the brightness reduced. If you see a blue light inside the computer it is usually a High tension leak. Better not to touch it and please turn it off and have it serviced. Opening it up and touching it could be lethal get it to a repairer
Posted on Jul 29, 2009
Help My HP L1706 17" LCD Monitor seems to have a Yellowish/Greenish tint on the screen, How do i sort this problem so that my screen is back to normal setting?
With the price of monitors these days, you can pick up a 19" new for less than 100. Or you can find them used for 50. I would replace it, but if you want to keep it, the go to HP web site and get an user manuel and try to adjust the settings.
Aug 12, 2014 | HP L1706 17" LCD Monitor
My monitor HP L1706 does not ignite but the green light blinks
Your screen is in sleep mode.
Its does not receive a signal from the pc.
Check for loose connections or a damaged cable.
Your monitor could also have a defect internal.
Maybe also your graphic card in the pc.
Good luck.
Mar 03, 2011 | HP L1706 17" LCD Monitor
Hp L1706 having white plane raster when i get it ON.
White/gray glowing screen means the T-CON on the LCD panel may have bad T-CON board or it is not getting the 5 or12vdc from the main board. Check the caps on the power supply/inverter board first.
http://s807.photobucket.com/albums/yy352/budm/HP%20L1706/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 28, 2011 | HP L1706 17" LCD Monitor
My hp L1706 flat monitor display not working properly. It will be takes long time to display.
Look for bad caps with leaking/bulging tops/seals in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 30, 2010 | HP L1706 17" LCD Monitor
HP L1706 monitor - will not power on - green light keeps on flashing
I had the same problem and replaced 2 bulged capacitors, screen is working fine again! (1000µF 10V)
Jun 04, 2010 | HP L1706 17" LCD Monitor
How to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
Mar 30, 2010 | HP L1706 17" LCD Monitor
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
