After turn on TV, it show the Samsung logo and then turn off. So again and again. May the software fault? How to fix it?
I don't think this is a software issue, I would check the PSON voltage and see if it stays at either a low or high reference. Get a meter on that pin, turn the set on and you will see it change when the set comes on, does that voltage go back to the level it was at when the set was off or does it stay the same even though the logo goes away
Hi try here Smart TV How to perform Factory Data Reset
SOURCE: TV shutting off randomly
it looks like a faulty mains board. you need to upgrade the tv software with the latest update. if the tv is not accepting the upgrade then it can be a crook mains board.
hope it helps! please rate my comments :D
SOURCE: Fault with Samsung PS42S5H
sounds like the lower y-sus buffer! take off the back and give me the pcb number should start with Lj92
SOURCE: Its not getting started.just showing
Do a Samsung b3310 Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in). Or flash your phone
SOURCE: My samsung e2100b keeps flashing
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks...
SOURCE: it only showing the samsung
Hello.
Go to this link:
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=SGH-E250
Click software and then Download Samsung PC Studio.
Then install it.
Connect the phone using a USB cable ( you have instructions on the screen if you need them).
Then click Upgrade Mobile Phone.
WARNING! Have a FULL battery and do not disconnect the phone until after the update is done!!!
By this you will update the software inside the phone and it could fix the problem.
If the phone is not recognized by the software you just have to take it to a Samsung dealer. There is no safe way to try to fix it.
Please don't forget to vote me.
Regards,
Achil
