Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Mould on gasket inside door
I have exactly the same problem . If I'm away for a week the machine stinks when I come back and I am constantly having to bleach it which can't be good for the rubber.
  • 82 Answers
U need to clean the door seal with a cream cleaner then put the machine on a boil wash with soda crystals in it or but the lime and gunge descaler from espares
Posted on Jul 29, 2009
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
Mold on inside rubber band and mold in soap dispenser and in back of soap dispenser.
This is quite a common problem and difficult to avoid unless you leave the drawer and door wide open all the time when the machine is not in use (which isn't very practical for most people!). You will find that painting the mould with thich household bleach and leavingit overnight will remove most if not all of the mould. If the first night doesn't get it all out, paint it up again for another night.
Note: You need to be very sure that you have washed all the bleach away after you have done this, so as not to bleach any clothing that then goes into the machine. ash the drawer and rubber thoroughly by hand, paying particular attention to the partially concealed area at the bottom of the rubber gasket between the inner and outer drums. I would also suggest that it is worth putting the machine on a hot wash while empty, to clear any last remnants of bleach.
Aug 25, 2011 | Kenmore HE2 Plus Front Load Washer
I have front loader washing machine and the rubber has got mould and having difficulty in removing the black mould
  • Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
  • Tips for Preventing Mold & Smelly Problems:
    • Always leave the door and dispenser unit slightly ajar after the laundry is done. Front-load washers and the detergent/softener dispenser drawer must dry out.
    • Never leave a wet washload in the washer overnight; remove it when the washing cycle is complete and leave the door open.
    • After a load is done, always rotate the drum with your hand to see and remove all items. Some could be sticking to top or sides of the washer drum.
    • Use softener sheets in the dryer instead of liquid softeners in the washer.
    • Liquid detergents may leave less residue than powdered formulas which may not dissolve properly.
    • Use less than the recommended detergent level for your load. Too much detergent can cause a residue build up. Experiment until you find a minimum measurement that delivers a clean wash. This is also a money saver.
    • Occasionally wash some loads such as whites, linen and towels in warm or hot water to help flush out wash residue.
    • Always clean your washer as per your product manual. High efficiency front-load models have a cleaning cycle and it's imperative that you periodically run this cycle as directed.
    • Check the gasket just inside the door opening and remove any visible debris. You can also wipe it to speed the drying process.
    • Always use HE detergents with high efficiency front-load washers. Specially marked HE laundry detergent is low sudsing and is recommended for these low-water washers.
    • If this advice was helpful a vote with the thumbs up would be appreciated. Thanks.
    Apr 08, 2011 | Ariston Technologies Ariston AWD12 Front...
    The rubber gasket has gotten very moldy since it continually collects water. How do I clean the inside of the gasket to remove the mold?
    Use a solution of bicarbinate of soda in water to remove the mould. If that does not work you can purchase a mould remover for bathroom tiles that will do a better job.
    It is recommended to leave the door open when the machine is not in use so that any residual moisture will evaporate and you will not have this problem in the future.
    Jan 22, 2011 | Miele W310 Front Load Washer
    Build up of mold/mildew on rubber gasket. Makes
    you need to purchase a package of 3 tablets called AFRESH at your local appliance parts store and follow the directions on the package. also, leaving the door open a bit after each wash will help.
    Oct 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
    My 2 year lold front load GE washing machine has developed a lot of mould in the rubber gasket on the front of the machine. I have tried to bleach it but the mould remains. It causes the cloths to have...
    on my lg, there are two small drain holes in the folds of the gasket that got plugged up with lint and stuff, unplug them if you have them. also i leave the door open after wash to let it dry out
    Jul 24, 2009 | GE WBVH6240F Front Load Washer
    Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
    This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
    Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
    Door seal
    Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
    The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
    Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
    You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until ot is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
    Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
    Jan 15, 2009 | Electrolux EW1000i Front Load Washer
    Bosch Nexxt series washing machine front gasket mold
    Hi.
    The quickest way to solve your problem is to fit a new door seal.
    Then each time you finish a wash, clean and dry the door seal.
    At least once a week, depending on how often you wash, do a hot wash with powder, but no clothes in.
    This is called a maintenance wash.
    This should solve your problem.
    The door seal probably got into its present condition because of several different reasons, namely:washing at too low a temperature-not using sufficient powder- amongst other things.
    the mould is actually living bacteria, not a pleasant thought
    Please positive feed back if you find this helpful
    Cheers and good luck
    Nov 24, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
    Changing the door gasket on Hotpoint Ultima WD860
    Managed to work it out myself how to take the old door gasket off and attach the new one. Thanks. Machine working okay with no leaks or mould anywhere now.
    Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
    Rubber door seal mouldy
    Wouldn't normallyexpect a few mould spots to leave that bad a smell, so likely you've got two distinct issues.
    Starting with the water trapped in the seal: Open the door and very carefully slip your fingers into the seal where the water is gathering (to stop your hand getting trapped between the drum and the outer casing, put your other hand inside the drum and push it up out of the way - just be careful not to let it spring back too fast).
    At the very lowest point,of the space inside the seal, either at the very front or the very back (so tucked into the corner between the floor of the seal and it's front or back wall), you'll find a little drainage slot. Once you've cleared the inevitable blockage from this slot, your seal problems should vanish.
    If the foul smell is coming from inside the machine, the problem is likely to be grey sludge inside the works of the machine. This is usually caused by modern detergents not being quite as good at working at 30 degrees as they claim to be. The answer is to run a cycle every now and then with no laundry, detergent, or conditioner in the machine, on the longest, hottest programme the machine will support. This should be sufficient to dissolve the rotting sludge and pump it away down the drain.
    A.
    Apr 06, 2008 | Zanussi ZWF1440 Front Load Washer
    Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
    272 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
