Question about MSI K8MM-V Motherboard
Hi i need a diagram to show me where the small conectors go there 2 red +5v 2g black 2 white - data 2 green +data thanks
    Guru:
  • 1,894 Answers
This diagram will come along with you manual. else you can download the manual from their site directly for free of cost.
Posted on Jul 29, 2009
Name of wire based on color coding wire
Special (only on the ATX conector)
-Green is PSon(put a wire between green and black to turn the power on)
-Gray is PWRGOOD
-White is -5V(optional)
-Blue is -12V
-Purple is 5VSB(Always on when the PSU is plugged on)
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
-Black is Ground (0V)
Dec 20, 2012 | Lite On LiteOn 204Watt PA-4022-6B Power...
Wire name based on color coding wire
-Gray is PWRGOOD
-Blue is -12V
Power
-Orange is 3.3V
-Red is 5V
-Yellow is 12V
Dec 20, 2012 | Lite On (PS-5101-2B) (ps51012b) 145-Watt...
My computer just died the morning. I removed the
red- +5v
yellow- +12v
orange - +3.3
black- 0v
blue- -12v
white - -5v
green - ps-on(+5v)
gray- power good(+5v)
purple- stand by (+5v)
disconnect smps from motherboard give the power to smps and short green and black wires and measure the above voltages
Mar 19, 2010 | Antec SmartPower 2 SP400 400-Watt Power...
ASUSP4SD-VX Can not figure out how to configure plug for front USB panel to motherboard, when using this mothervoard in a generic case.
your motherboard only supports USB v1.1, make sure those are they type of connectors on your case, and if so, open this document and go to page 2-16 for diagram: http://dlcdnas.asus.com/pub/ASUS/mb/sock478/p4sdr-vm/e1104_p4sdr-vm.pdf
if the case only has USB v2.0 plugs, you cannot connect them.
Jun 28, 2009 | Computers & Internet
Washing machine moter
green is ground, white is neutral, red/black is usually hot on a 1 phase 110-120v motor. (normal colors are black, white, green).
if three phase, (208-220v), green is ground, white, is neutral, black/red/blue are hot. (only uses 2 of these, so there should only be a total of 4 wires). once you have the wiring connected, turn on the motor, and check the rotation direction it turns. if it turns backwards, reverse the red/black wires, the red/white wires, or the black/white wires.
be sure you look at the data plate on the motor to determine one or three phase motor.
their should be a small diagram of which wire inside go to which other wires inside on a three phase motor and for which voltage, and are usually numbered on the individual wire.
good luck.
Nov 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Which cables go where???????
RED - YELLOW - GREEN - BLACK -----
1 3 5 7 9
2 4 6 8 10
May 08, 2008 | MSI PM8M-V Motherboard
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
Apr 18, 2008 | E-Machines eMachines Desktop PC
The usb cable are de-attached from the bord of my webcam
+Data
Green
-data
White
VCC
Red
GND
Black
BLACK BLUE BROWN are used as Ground
Apr 15, 2008 | Xirlink Promax Webcam
MSI K8MM-V Motherboard Logo
154 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
