Question about Marantz Home Theater Systems
Infrared codes i have a marantz SR-66 5.1 and need the ir code for a new remote
  • 93 Answers
SOURCE: IR codes???
I think that you need brand codes for any piece of equipment which you want to control with your universal remote.
Posted on Oct 08, 2007
0 characters
1 Points
Nakamichi nk12 remote code
Scot, Nk12 universal remote code, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Infrared Hex Code Database Nakamichi Model List
Aug 21, 2016 | Nakamichi Home Theater Systems
Codes universal remote will any universal remote work on my system
Most universal remotes have many codes for many manufacturer's products stored in them. They may not have the exact code for your device, but they probably have codes that will work most of the functions of your device. If you'd like one that has direct mapping to keys, you'll need a learning remote. These remotes allow you to point your remote's IR emitter at the learning remote's IR emitter/receiver and map any or all of the buttons to the buttons you choose. On mine, I created a spreadsheet ahead of time that shows what buttons are mapped to which commands.
May 09, 2014 | RCA RT2390 System
Niles infrared microsensor blinks continuously
1. The microsensor could be dusty
2. The remote could have a stuck button
3. Something is generating an infrared signal that the microsensor is detecting
4. Batteries could need replacement
Jan 01, 2014 | Niles Audio MS220 Surface-Mount IR...
Control Curtis dvd6041 with dish-network remote 5.0 IR
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for our more popular models of remotes and the instructions for addressing the remote to your DVD player. I hope you find this information useful but if it does not work or you have any further questions please let me know I would be happy to help further.
Remote model #'s Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 1594, 1605, 1607, 1675, 1554, 1592, 1677.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 1594, 1684, 1554, 1605, 1607, 1592, 1678.
4.0 and 4.4 IR/UHF remotes - codes 1684, 1554, 1594, 1605, 1607, 1592.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 1592, 1594, 1605, 1607, 1554, 1683, 1675.
20.0 IR and 21.0 IR/UHF remotes - codes 1585, 1554, 1592, 1594, 1685.
Instructions for addressing the remote to the DVD player
  1. Press and hold the AUX mode button until all mode button back lights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment.
    Note: The light will blink off after each digit is entered and then return to a steady light.
  3. Press the POUND (#) button.
    If the code entered is valid for the remote, the mode light flashes three times.
Oct 10, 2011 | Curtis DVD6041 System
My Bose V30 system with the RCV1T-27 remote wont send the IR signal to my Motorola DCT 6416 if im not standing right in front of the Bose display unit. The light on the display still blinks as if its...
Check the cells in the battery compartment of your remote control handset. Replace it with new ones and check. Still you poise this problem, the intensity of infrared rays come from your remote control, or the sensitivity of the infrared sensor inside your bose front panel system may have the trouble. Just replace the infrared LED of your remote control with an other one of same type. If it does not helps you, repalcing the infrared sensor will reftify your problem. OK.
May 05, 2011 | Bose Lifestyle V30 Home Theater System -...
I have a Panasonic home theater and am looking for a code that will work with either a starchoice IRC 550 or shaw direct ir/rf 600 remote
This is the manual for the irc 550 ..and in the manual you have the codes for audio (cd ) which I believe to be the ones you need to use..They are on the end of the manual ..But ! If you read the manual carefully you see that it actually can pick-up the codes automatically if you follow certain programing procedure.described in the manual ..
Jan 28, 2011 | Panasonic Home Theater System System
How do i get my Bose Lifestyle remote to control
call bose tech support and register your lifestyle system with them, they in turn will start sending you update CD's those CD's may include the new IR databases that would help you find the right code. the other alternative is to call VIaSat and find out what brand's IR codes they are using( and in the IR menu on the bose try that brand's codes) A lot of manufacturers will use the codes from Motorola(worth a shot) the alternative option is to program a universal remote to control your bose, and all your equipment (if your equipment is hidden in a closet, get an RF remote, I program these for my clients all the time (for their bose systems))
Sep 12, 2009 | Bose Lifestyle V30 Home Theater System -...
Need v30 bose code for remote
Bose V 30 works on Radio frequency ............. so you need to have a unversal radio frequency remote conrol..... no IR (infrared) remote can control a bose lifestyle product..
why not use your bose radio frequency remote( the v 30 remote) to control the dvr plyer from motorola.. you can used the remote even to control your tv and other deices ..
all codes for your other systems are available in th e system settings option under remote control category to set up your system to control other devices
Feb 21, 2009 | Bose Lifestyle V30 Home Theater System -...
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Nov 15, 2007 | Onkyo HT-SR800 System
IR codes???
Oct 08, 2007 | Astar /KDX (HT-3300) DVD Home Theater...
Open Questions:
Marantz NR1501 issue: Sound output has stopped for everything except radio. All other sound has stopped. It worked fine until recently. We do have a four yr old though, who might have pressed remote control buttons messing with settings, possibly. But I have tried playing with settings (and downloading manual, here: but to no avail. The amp is connected to both Blueray (IN) and TV (OUT) via HDMI cable. I have checked that audio from the blueray works fine (when connected directly to TV). When output via the Marantz n1501 amp, the video image works fine on the TV(via HDMI), but there is no sound from the speakers... I checked volume, mute, various other settings. We have four speakers connected currently. No centre at this stage, but I reconnected one speaker to centre pins just in case it was only coming through the centre speakers for some reason, but still no luck. Same issue for DVD and Wii, incidentally (all DVD input, I think). On a separate (I think) issue, I can't seem to get it to go into standby mode. It generates quite a bit of heat overnight, and so we have to switch it off completely, which means I would need to change the settings every time so that sound came out of all four speakers (it would revert to just two speakers after every time I switched it off). Anyway, this is probably a moot point, because currently there is zero sound from the amp altogether.
Sep 15, 2013 | Marantz 1501 7.1 Channel 50 Watt Receiver
Home Theater Systems Logo
Top Marantz Home Theater Systems Experts
BJ Russell
Robert marquette
Andrew Taylor
Andrew Taylor
Are you a Marantz Home Theater System Expert? Answer questions, earn points and help others
