Sewing Machines Logo
Francis Kym Posted on Oct 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Designer se screen is blank for a long time before the machine fully starts. The dealer has tried a Transformer and a Motor to no avail. The dealer thinks it is a pc board. It seems they can't get one
NOEL
Level 3:
Top Expert:
  • Sewing Machines Master 8,606 Answers
  • Posted on Oct 31, 2017
NOEL
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2318956
Points
68630
Not sure if your dealer has looked on this link.
but go to this link and see if this is what he is on about.
or get him to have a look at this link it might help you out.
or he might find the part on ebay..
husqvarna viking designer se parts pc boards Google Search
5 Related Answers
AvioriX
ExpressFiX
  • 691 Answers
  • Posted on Jan 18, 2008
SOURCE: Communication with PC
Hi Monika
Issue can be related to driver. You can retain the PC Designer program. However you can reinstall the driver. You can go to Control Panel click on the system Icon then click on the hardware and device manager, Check is there any exclamation (!) or question (?) mark on any devices. try to locate Machine's driver and uninstall then reinstall. Please post for further assistance. Please indicate outcome of your diagnostic.
Good Luck
με φιλικούς χαιρετισμούς.
Anonymous
  • 87 Answers
  • Posted on Mar 18, 2009
SOURCE: husqvarna designer se
There are 3 main fixes for a freezing SE.
1> Have the latest 12501 update installed, the 12124 had a problem.
2> make sure you have the right hook (the 2 older hooks have this problem.
3> The newer tension assembly with the grounding strap needs to be in the SE as well.
4> there were only suppose to be 3 but if your screen gets weird when it freezes, it could be the video transformer
Anonymous
  • 87 Answers
SOURCE: Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
deborahcha
  • 371 Answers
  • Posted on Sep 24, 2009
SOURCE: I recently purchased a Husqvarna
Sorry. Sounds like a dead LCD screen. It will have to be replaced by an authorized Husqvarna Viking dealer. Be sure it is an authorized dealer. Check the Husqvarna Viking website for dealers close to you. Http://www.husqvarnaviking.com/us
Anonymous
  • Posted on May 04, 2012
SOURCE: Viking designer se screen is stuck in welcome
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
2answers
I have an Viking Designer SE Sewing/Embriodery machine and I just starting exploring Embroidery? My thumb drive won't show the designs on the Embroidery machine, but they are on the USB thumb drive.
Most newer USB drives are not compatible with the Designer SE. Only Husqvarna Embroidery USB Sticks are guaranteed to work with this sewing machine. https://www.manualslib.com/manual/827718/Husqvarna-Viking-Designer-Se.html?page=21 . The entire manual is available from https://www.husqvarnaviking.com/support/DESIGNER-SE . One tip: try making sure that the file is not inside a folder on the USB stick. (In File Explorer, you should open the drive and see the file in that first list/window. If you build the folders on the sewing machine, it's less likely to be a problem.)
Other USB sticks can sometimes work. However, you need to format the stick at the sewing machine before putting files on the USB stick at the computer. 2GB and larger USB sticks are the most likely to give problems. 32MB to 1GB sticks are more likely to work. Only one person found an 8GB USB stick would work with the Designer SE. Most new USB sticks are formatted with a NTFS format. The sewing machine may be looking for a FAT16 or FAT32 format. The other possibility is limited USB drivers on the sewing machine. (I've got an Ag GPS position system that won't accept any USB stick unless it is labeled as "Works with Windows 98". Those USB sticks didn't need the OS to download a driver from Windows Update when they were first plugged into the computer.)
I hope this helps.
(The Designer SE could talk directly to Windows XP or Vista via USB. However, the programming probably had more in common with Windows 98.)
Why does the screen on my viking designer 1 se/le go blank but still sews
the motherboard or screen could be going out, it would be a good idea to have the machine checked
The screen on my viking designer se/le goes black
Your screen may need to be replaced. Take it to a husqvarna dealer and see if you can get a free estimate.
1helpful
2answers
Viking designer se screen is stuck in welcome screen when turned on. update did not help me! my steps: 1turn on Designer SE le and connect to computer. 2install Designer SE 3D embroidery Software...
1helpful
Husqvarna designer 1 won't turn on..stitching had messed up and cleared out bundled thread and now screen won't light up.
If there is no noise, like the machine is calibrating or setting up, then more than likely the fuse on the transformer has blown. If the needle motor and feed motor make their usual noise and the lights come on but the screen won't come on, chances are a connection inside the machine is your problem. If the cable from the display screen becomes unplugged, the machine will "start up" but nothing will be displayed on the panel. If when you turn on the machine, you touch the screen and hear the "click" sound the screen makes then its a problem with the display screen only. (there are 2 screens, the one you touch your finger with is the touch screen and the one behind it displaying the picture is the display screen.)
1helpful
2answers
Husqvarna designer se
I recently purchased a Husqvarna Viking Designer SE online and just unpacked it obvously from the original factory packing. The machine turns on, lights come on, motor runs and the machine even sews...but,...
My Designer 1 screen is blank.
Phone the technician who worked on your machine previously and tell him/her what has happened. It would appear that the repair was not done properly. Make sure they understand the inconvenience they have put you to and ask can they effect the repairs as quickly as possible.
2answers
I accidentally started sewing with wrong foot and needle hit the plate and broke. Machine won't sew
This is just a guess since I haven't seen exactly what's happening, but my guess is that the drive belt has come off. You can hear the motor running because the machine is attempting to bring the needle to it's fully up position. Since the machine isn't turning, the motor will run faster and faster until it hits full speed.
1helpful
DESIGNER SE breaking needles
Sounds like the needle to hook gap needs to be adjusted, i.e. the needle is striking the hook when in the lower position. As the needle becomes dull, it probably bends slightly causing more contact and hence breaking. I would try another dealer if you think that might help., You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
