Back to:
Tags:
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge and Freezer losing cooling (by 11 users)
posted by TnTB on Nov 23, 2007
Hello!
I've noticed for the past few days that the freezer isn't as cold as normal. Today I noticed the refrigerator wasn't cooling properly as well. I've set the temperature to the lowest temp on both the freezer and refrigerator.
Can you help me? I have the Fisher and Paykel Active Smart (Fridge on top, Freezer on bottom). It's only 1 year old!
Thank you!
T. Boyd
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
10 Other Users Have The Same Problem
Comment by Guest, posted on Oct 04, 2008
Same problem - fridge and freezer of the E522BRX are not cold enough to keep food. Purchased in Aug 2008, had evaporator fan replaced in September 2008. 24 hrs later, same problem. Called for service again.
Comment by Guest, posted on Sep 05, 2008
Same problem...after repeated changes of Fan, condensor and several other parts, they replaced the whole fridge.
Comment by Guest, posted on Aug 09, 2008
not freezing after power outage
Comment by Guest, posted on Aug 02, 2008
fridge not cool milk wnt curredled and frezzer has ice build up
Comment by Guest, posted on Jul 20, 2008
refigator nd freezer not cold and hear a clicking noise
Best Solution
posted on Dec 10, 2007
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Fridge and Freezer losing cooling:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Fisher and Paykel Active Smart E522B Bottom...
Had tech come out due to water all over floor. He...
My fridge which is 5 years old will only swich on manualy...
There used to be lot of ice frozen at bottom of the fridge...
door was slightly ajar last night because something kept...
I have a Fisher & Paykel Active Smart refrigerator...
10 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 27, 2008
freezer isnt cooling
freezer inst cooling everything is running
Comment by Guest, posted on Jun 05, 2008
Severe storms in the area. Don't know if that had anything to do with it. Unit is only 3 1/2 years old. I left for work 08:00 am and refrigerator/freezer OK, I think. Lights were on and milk was cold. Came home at 09:30 p.m. freezer complete defrosted. Water from ice maker ran down inside and out the door dispensor. refrigerator slightly cool. Turned unit off 30 seconds, then on. Unplugged unit 30 seconds, then plugged back in. Hear a clicking sound periodically but it does not come on.
Comment by Mental Model, posted on Dec 25, 2007
I have a Frigidaire FRS24MWGW1 Side by Side, it would not freeze, it would get to about 34 and the fridge part never seems to get cold. Yesterday it was about 74 in the freezer and I called a repairman. Had a starter switch replaced and it took about six hours just to get down 34, still not freezing.
I guess I need to call him back out, but first a question. Should the defrost fan always be turning back on? It seems to be always cycling and if it is, how can the freezer ever get to freezing temps? The defrost timer was replaced about 2 years ago, fridge has never ran the same since.
Is there something I can do or replace?
Comment by Guest, posted on Dec 07, 2007
i have a servis f/f frost free,model no m8338s,yesterday the fridge door fell off as my wife went to put the shopping in. the top right hand hinge holder had broken in half.tuened the door upside down and put back on .thought i had solved problem.freezer still works o.k but,fridge will not ,any ideas? i have turned the thermostat up to full and also to the reccomended mid point,to no avail.still no joy,yours desperate, no spare wedge at this time of year anyone please help!!!!!!!!
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
