Toshiba TV Model 29AZ8UN
I understand from the repairers that the TV has a timebase problem and the board DFS module MDFS01 requires replacement. Please advise where we can source this from. The TV was purchased in the UAE.
  • 244 Answers
You need to find a reseller of TOSHIBA TV possible they really know where you can buy the spare parts. Check this website
and also this one
Posted on Nov 24, 2007
Hi I have a toshiba dfs 100 hyper progressive rear projection 67" tv, model 61A9UA and when i turn on the tv rows of what look like are black small rectangular boxes appear. Its still there wether i...
hi i have a Toshiba Dfs 100 & hyper progressive i hve no idea what wrong with my tv.. when i turn the on button the box down the bottom its on nd showing blue color..**** nothing showing on the screen.. pls help me thnx
Aug 09, 2011 | Toshiba Televison & Video
You need an upgrade kit part: TV-3940-01.. But the part is backordered for three months. $150.00
Oct 16, 2008 | Televison & Video
Tv takes about 20-30 minutes to warm up.impossible to view until it has warmed up. after warming up,it's still wavy along top 6" of screen.colors all seem to be fine.any opinion is greatly...
From the symptoms you describe this souncs like what toshiba describles as the "hypermodule" problem. These sets had a problem with a cuircit board known as the "hypermodule" Now in the past it was common to replace this cuircit board.. trouble was they began to run out of theml so toshiba figured out that the board could be repaired rather than replaced... TO repair such a board is quite labor intensivel it involves replacing 11 very small micro components call capacitors. I have replace them a few timesl First problem you have is removing this board take time and effort.. secound problem is these parts are very VERy small. and even the most skilled techninians need a magnifer and a very steay hand; It can be repaired but the time and skill required dramaticly add to labor cost .. it cost on average around 400 takeing several hours to complete... Well at our shop it cost that.. it varies.. my only advice is if you find someone make sure they have experience repairing the hypermodule. willtab.jpg
this is the module. it is in a metal sheild stang vertically on main board. the tiny circles are called capacitors to fix 11 need is so easy to damage the board.... once damage replacements
Mar 01, 2011 | Toshiba 42H81 42" Rear Projection...
I was told by repair shop that the hyper module on my Toshiba 53H71 has gone bad, and they were not available for unit to be repaired . Any help ?
there are a few shops that can physically repair these. I have personally repair a few. but is very very tricky... it requires some very trick soldering to some very small was replaceing so many of these they gave instruction on fixing these. it involves replacing 11 very small micro capacitors.... like i said very labor intensive. my shop generally charge 250 for the repair. just depend on who you get. WARNING this is the kind of repair that the technician can easly do more damage than good so get a respectable experince tech to facilate this repair
Nov 03, 2010 | Toshiba 53H71 53 in. Rear Projection...
Have a toshiba 50hp16 plasma tv with a 12in black vertical line in the center of the tv can it be repaire tech told me its the boards that need to be replace can it be something else the sound is their and...
it is commonly the module it has many parts there connected it is the one that produce the image in your tv it must be replace a original board try to consult a service center about the module.
Oct 15, 2010 | Televison & Video
A band of color for a picture on my 50H72 toshiba projection tv suddenly becomes either half a picture with a thick band of color on top or just becomes a band of color with no seeable picture. We have...
The most likely cause of a problem such as described is failure of the "Hyper Module"; this is one of the "stand-up" PCB's on the main signal PCB (which is the one on the right when viewed from back of set). These modules have a history of failure of the multiple electrolytic "surface-mount" capacitors; successful repair of hyper modules usually entails replacing all caps on the board, and often some solder repair as well...the degree of soldering expertise required to adequately service such products will usually preclude all but professional repair
Mar 04, 2010 | Toshiba 46HM95 46" HDTV
I have a toshiba tv that power up the light on the power button stay red the model # is 57h83 couild you help me out chris
Maybe I can help. This symptom is caused by so many different failures inside the set. Most commonly, convergence chips go bad. Next, capacitors get weak in the power and sub power supplies. And finally, the hyper module eventually needs to be rebuilt by replacing all low value surface mount capacitors. All of these repairs will be needed on your set. All of these repairs require test equip and soldering / desoldering equip. In most cases you can have the set repaired for 200-350 and expect the high end of that range. If you attempt repairing it yourself, you can usually check for open pico fuses on the board, then disconnect the convergence yokes to see if set comes up temporairily. The best I can do is to inform you of your options and what to expect. Overall, it is a good, long lasting set and if it is repaired properly the first time, you should get at least ten more years from it. Well worth it in comparison to a new set that commonly requires an extended service plan just to get through the first five years. Good luck, Russmann.
Oct 13, 2009 | Toshiba 57H83 57" Rear Projection HDTV
Toshiba Picture Frame 2 36zp38 No picture
This fault is not something you can repair your self.
It is a problem with the DFS module normally dry joints but it is near imposible to do without specialist equipment.
So definately take to repair shop.
Do not attempt this repair.
Sorry for being bearer of bad news.
Dec 15, 2007 | Televison & Video
Poor digital picture Toshiba ZP38 TV
Hi. Sounds like DRY JOINTS WITHIN DFS MODULE. This is a pcb within a rectangular metal screened box on the left hand side of set when looking from the front. Will need resoldering be carefull very fine print will need decent soldering iron with fine tip & poss magnyfying lamp to aid looking. If your not at all sure take to repair shop. This TV is nice set has one of the best crt pictures you can get.
Sep 05, 2007 | Toshiba 32AF42 32" TV
Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Mar 19, 2007 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
