Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Is a total Alkalinity 240 ok or what to do...thanks
  • 297 Answers
Way to high
Alkalinity 100-140ppm
Chlorine 1.0-1.3
PH 7.4-7.6
Stabilizer ( Cyanuric Acid ) 30-50 ppm
Posted on Jul 30, 2009
  • mark Gianotto Jul 30, 2009
    I should have gone further
    Alkalinity has a lot to do with PH readings so you will need to keep an eye on that as well until you get everything in check
    There is no specific chemical to raise or lower Alkalinity
    What you will use will be PH Down this will in turn lower both- Just read the directions and apply for your size pool
My Raypak spapak 11kw 1102 has deveolped a leak at the base of the heater tank. Small pin hole leaks in the copper tank. This is the second one to leak (replaced one two years ago) at the same place? Why...
make sure pool chemistry is in balance too low of PH and too low alkalinity will eat through the heat exchange copper PH should be between 7.2 and 7.8 alkalinity should be between 80 and 120
Oct 01, 2012 | Raypak Spapak Electric Spa Heater -...
Hayward vari-flow valve sp714 cloudy water
Otherwise chemistry fine?
whenever someone is vague about chemistry residual readings, but provide a pH reading, I'm always Leary.
  • bring pH up to 7.6
  • Balance Total Alkalinity at 120 ppm
  • Bring Hardness to at least 200 ppm
  • Keep Chlorine level at least 3.0 All the time
  • ISO Cyaniric acid / stabilizer at least 30, not exceeding 80 ppm
  • Use a Natural Clarifier weekly - rate = 1 ozs per 5000 gallons
  • Use Algaecide (not from Kmart!) weekly
  • Clean filter whenever pressure approaches 8# over starting
  • Filter for at least 1 turnover per day. This is usually 8 hours in most regions
Follow this, should be good
May 25, 2012 | Hayward SAND FILTER, PRO SERIES
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
Have a pentair ccp320 filter.brand new last year.pool water has been cloudy for two weeks.water is balancedexcept akalinity is high at 200.suspect filter problems.water was clear for a month.cleaned...
Total alkalinity can be lowered by adding muriatic acid or sodium bisulfate. Acid may be added in doses of up to 1 quart per 10,000 gallons. Total alkalinity tests and further required additions of acid can be made every 2 hours.
Jun 28, 2011 | Pentair Clean & Clear Plus Ccp320 Pool...
The copper level and free chlorine levels are normal in my pool , but the Ph and Total Alkalinity is off the chart , the pool is getting a little green algae on the bottom, and the filter and tubes have a...
Ger your calcium at 300 PPM even if you have a plastic pool. Then get the Alkalinity under control. You say it is off the chart ... but you Don't say if it is high off the chart of low off the chart. You will never get your pH proper until you get the alkalinity right. Sodium BiCarb to raise, muratic acid to lower. Goal is 100. When you get this number correct, you can adjust the pH. Don't try to correct this in a few hours ... go slow. Once the Alkalinity and pH is correct, introduce some dry chlorine ... shock the pool to about 20 ppm.
Is your salt around 3200 PPM? That is the goal for salt.
I hope this helps you with your pool.
Apr 28, 2011 | Intex Automatic Salt Water System for ...
Our ta keeps falling by fifty in like just a few hours why?
Presumably you are referring to Total Alkalinity - assuming that your test kit/procedures are OK, the reduction is caused by a build up of acidity in the water. The addition of sodium bicarbonate will neutralise the acid; the fact that the ta keeps falling suggests that you either have a large amount of acidity and you aren't adding enough sodium bicarb to complete the job, or you may be adding acid in the form of a pH decrease chemical. To raise the total alkalinity by 40ppm you need to add sodium bicarbonate at the rate of 700 grams per 10,000 litres of pool water. The desired ta is about 100ppm.
You don't say whether this is a swimming pool or a spa pool - if it's a spa pool I suggest you drain it and start with a clean slate, so to speak. If it's a swimming pool you are probably being timid with the sodium bicarb!
Jan 24, 2011 | Pool & Spa
My saltwater system produces chlorine but disappears fast
first of all your problem is a few things combined.
First lets learn what consumes chlorine
Heat,sun,rain,sun tan oil 3 of swimmers
you may need to run your generator 12 hours some nights it all depends on what kind of day it was and what the chlorine was to start with
Also if you do not have your salt as close to 3000ppm as you can then you are also not generating enough chlorine even if you are not triggering an alarm for low salt
you can not be below 2800 and no higher than 3800ppm
a test kit is available get the strips that reads #'s not the color strips for salt reading
Also you should be using a chlorine stabilizer to help hold the chlorine level this is only a help situation. it will not completly remidy your chlorine level going low if all the elements I mentioned are happening at the same time
Also be carefull not using the pool that is the worst thing you can do. You may go green quick without people in it stiring it up
I also recommend you use a non foaming algaecide every 5-7 days just follow directions for your gallons of water
By the way bromine tests are really not for pools they are designed to work with the hot water and chlorine level of a hot tub
your ph is fine, about in the middle alkalinity is what drives your ph so worry about the ph level and chlorine and you are good to go
Jul 09, 2010 | Intex Automatic Salt Water System for ...
Noticed water leaking a lot from bottom of unit. Looked like a pretty good leak. Unit is 9 years old. Leaks when Pump is running
More than likely the heat exchanger. Has the pH and Total Alkalinity been low? Check the Pressure/Temp relief valve, thermostat probe, high limit switches, etc. first though...
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
No dryer or washer control will start the unit running. appears no power...we checked for 240v at plug it ok...
Check the 240 vac again, but measure each leg to neutral while attempting to start the appliance. Each "leg" should measure approx. 120 VAC< (half of the total voltage) and should not change when the unit is started.I think you will find that the two 120 VAC legs will read OK until start up. If the voltage value on one leg drops to 60 VAC or less and the other leg increases by the same amount, Then there is a problem with the neutral wire or the connection between the ground of your appliances and earth ground. This is very common, particularly manufactured homes. Most dryers, for example, use 240 VAC to run the heating element, but also use 120 VAC (one leg of the 240) to provide power to operate the control panel. So... every time a start is attempted, the line becomes unbalanced, the 120 VAC to the control panel suddenly drops, the control panel resets, removing the load, the 240 VAC line becomes balanced again and appears normal.
Jan 07, 2010 | Washing Machines
WHAT SIZE BREAKER IS NEEDED FOR 240 VOLT ELECTRIC BASEBOARD HEATE
If there is a 15 amp breaker on this circuit now. Then I would assume the the wire to this breaker is only capable of handling that size and NOTHING larger. There are to many variables. You need to know the maximum amp draw rating of the device. The wire size going back to the service entrance (fuse box). You will also need to know the total power draw of the service entrance to determine if the box can handle the total load. Are there any other branches off of this circuit? I suggest that you get advice from an electrician. If you overload the circuit, you may think everything is ok. But you can cause a major problem. I do not think that you want to take the chance of overloading a circuit. This can cause a fire and or death. Have this inspected by a professional. If you insist on doing it yourself.... contact your local building inspector for guidance.
Apr 21, 2009 | Fahrenheat Electric Convector Baseboard...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
263 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
