Question about Gateway GT5242E PC Desktop
Computer will not boot up when turned on. light on tower not lit just runs no screen images
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
First step to determine the damage and is again re-work order, open the cover of the CPU and remove the following parts, the first memory is the second video card and third is the IDE cable connectors, clean the small feet and the second memory is please clean feet video card if it is you video card, good luck
Posted on Jul 29, 2009
Toshiba Satellite l445d-s5976 won't power on
Well,that happend to my mom's computer and it was all working and was turned on but the image on the screen didn't show so I'm not sure how to fix it but I think you should send it to repair the same happend to my TV and it was sounding but didn't see the screen so I think the best thing you should do is sen it to repair or drop it off at Best Buy
Nov 24, 2012 | Toshiba Satellite L455D-S5976 Notebook
Screen was blank but power light lit. Rebooted power light lit (light blue but no working screen?
Shut down system by using poer button on tower then unplug tower. Turn power back on and boot in "safe mode with networking". When screen comes up, click on "start", then "control panel". Find and click on "device manager", open and click on continue. Click on box(on right) of "display adaptors". Do you see a warning, ?, !, or yellow triangle? If so click on that and follow proceedure. Right click on your device and in the list you should see "disable". If you see "enable" click on that and exit. Right click on your device again and click on properties. You should see "this device is working properly". If you are using on board graphics, not a graphics card, click on "drivers" tab. Then click on "automatically search for updates...". When finished, restart your system. If you have a graphics card you should update with manufacturer. Let me know make and model of card if you have one. If you are getting beep codes it could be your ram.
Apr 05, 2011 | Dell Inspiron One 2305 Desktop Computer...
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
Presario laptop screen turns black after bootin git up...
Try using a light on the laptop and check if the images are clearer.
Try booting into safe mode by pressing F8 at boot up.
If the same happens there as well then you will have to change the backlight of the display.
It is recommended for you not to open up the display to change the display light as you may run into damaging the LCD itself.
Best would be to contact the manufacturer so that they can get the right part replaced with a similar one.
Aug 08, 2009 | Compaq Presario 12XL125 Notebook
I'va had this pc for about five years. It turns on past booting but once it gets to the windows xp loading screen the Monitor goes blank and shows a no signal message. The tower ( an emachine) still show...
u have problem of disaply scren resolutio for that
when u power up the computer press F8 key then u see safe mode and other menu
then enter in enable vga mode .
then u can change screen resolution to 1024*768 in dispaly property
Apr 23, 2009 | Sony VAIO PCV-V200G PC Desktop
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Toshiba setellite black out
Sounds like the back light on the screen isn't working properly which will need to be replaced if this is the case. Check for a very dark image on the screen when it is booting up in a well lit room, if you can see the computer start up then it is the back light.
Jun 25, 2008 | Toshiba Satellite A60 Notebook
Blank
Unplug the monitor from the computer,
it should display the diagnostic screen on monitor in color.
if not reconnect it and boot computer or attach to a running computer with some stuff on the screen,
get a bright light and shine on the screen at an angle do you see the stuff/desktop.if you do the lamp or power supply is bad.
if the monitor is lit and the lamps work but no diagnostics then the video cpu on the monitor is bad.
post your findings here
Jan 26, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Black screen
The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
Feb 04, 2007 | Microsoft Realsync DS771 17 Black LCD 8ms...
Gateway GT5242E PC Desktop Logo
177 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
