Installed epson c62, put in new cartridges, printer seems to be working ok, but no text is appearing on the paper, have i missed doing something in set up. have tried cleaning nozzles
    President:
  • 627 Answers
Try a deep cleaning from printer properties and then draw a rectangle in word fill it with black colour and print it
Posted on Jul 29, 2009
Prints blank pages
check if there is still ink in the cartridge.also use a soft cloth and little water to clean the nozle of the cartridge.
Jul 02, 2009 | Epson Stylus C62 InkJet Printer
Epson r390 printer prints blank(no text on paper)
Check condition of head first. Move head to parking position (head cleaning position). From outlet pipe of head cleaning mechanics, do suction. It's there is ink, the head is not clog (and the flow of ink is ok). Make nozzle check. If nothing lines appear, the problem is in board (cause you just reset). Using resetter, do initial setting. Good luck.
May 31, 2009 | Epson Stylus Photo R390 InkJet Printer
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
Inkjet printer
Your inkjets are clogged, use a damp sponge to clean heads (located where the bottom of the cartridge is) put a paper towel underneath the cartridge holder to soak up water, allow to completely dry then run ink test (head cleaner) through printer utility...its worked multiple times for me
Jan 25, 2009 | Epson Stylus C62 InkJet Printer
Cleaning cartridge
Both the black and colour cartridge must be installed for the printer to work. So you will need two cleaning cartridges. If you only have one cleaning cartridge, make sure your "other" cartridge is not out of ink. If you are sure both cartridges contain ink/cleaning fluid, post a new comment with this information.
Nov 07, 2008 | Epson Stylus C62 InkJet Printer
Epson c62
Try a "hard restart ", which simply means unplugging the power cord of the printer, then replugging it after a few seconds have passed. If that does not work, then rerun the CD used to install the printer, Both techniques reprogram the printer to a certain extent.
Hope these suggestions help you out.
Jun 27, 2008 | Epson Stylus C62 InkJet Printer
Printer instilation
you have to download the drivers from the epson website then you can install
Apr 05, 2008 | Epson Stylus C62 InkJet Printer
Epson Stylus Photo R220 InkJet Problem
This is probably due to the waste ink pads needing replacement. If you still have this problem and would like help solving it, please post a new comment to this effect.
Mar 19, 2008 | Epson Stylus C62 InkJet Printer
37 people viewed this question
k24674
