If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
SOURCE: philips 50" plasma ysus board troubles
Check for shorts, blown fuses on ysus, if blown replace entire board, easier than locating many of the parts installed on the board.
SOURCE: ED14 on the powersupply of lrm-519 need replacing
This item is a MOSFET Power Switch. The part # FSDH0165D. Can be found below
www.mouser.com/Search/Refine.aspx?Keyword=512-FSDH0165D
SOURCE: how to conect a pc to a panasonic plasma th50px75u?
Panasonic didn't make it a simple matter to connect a computer to this TV since they didn't include a VGA input connector. You can still do it, but it will require some adapters or changes to your PC.
If you're using a laptop, you have two options. If the laptop offers an s-video output, you can use a suitable cable from there to one of the set's s-video inputs. If there's no s-video output, the other option is to purchase a VGA-to-component breakout cable, available at a number of online vendors (search with Google). This cable has the VGA connector to the computer on one end, and 3 RCA plugs at the other end. You would use this cable into one of the set's component video inputs.
With a desktop PC, you can still use one of those two options. In addition, there may be a DVI video output connector available as well. This is not common on computers with integrated video, but is frequently found on many newer expansion video cards. If your computer has this connector (or you install a new video card with one), you can use a DVI-to-HDMI adapter and connect an HDMI cable to one of the set's HDMI inputs. Many video cards with DVI outputs include one of these adapters already.
So while it's not going to be simple, it's certainly possible to connect your PC to this TV.
SOURCE: I bought my plasma tv over 1 year ago but only set
it's a defect. we call it red blinking death. the boards inside the tv has gone bad.
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
