To change the aspect ratio to default, do the video reset (while in standby (red light). Hold the power until it beeps once for turning on then once again to do a video reset)
After going into the video settings after the reset it should be there to change it. If you still don't get a picture try it on another TV. If there is still no picture you may have busted the HDMI port.
Thanks buddy. I tried that while PS3 was plugged into my Celestial plasma tv but still came up no signal. I then plugged it back into my little teco tv and it worked fine. Does that mean my HDMI is busted on the Celestial tv?
No problem. I would take a can of air duster and blow it into the Celestial hdmi as it may be dirty. Worth a shot. If that doesn't work then the HDMI port on that tv is dead and the solder will have to be reflowed or the HDMI replaced. Good luck!
Ok I will try that first. If not I will take a look at the HDMI socket and see if there is anything obvious. Cheers for the help Brandon. Much appreciated bud
Not a problem! Just as a tip to finish this off if the HDMI connector is reflowed and you still have problems even after replacing the HDMI port check the components in line with the HDMI by following the traces to it. There should be an HDMI chip driving it and possibly a surface mount fuse closer to the HDMI port that I would check. Good luck and feel free to update this so that others may be able to fix it as well. Bye and have a good one!
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
SOURCE: HDMI ON ILO 32HD
I use a Toshiba DVD Player SD-6100 and had the same problem when using a HDMI cable. The ILO TV kept saying no signal. I don't know how to make the PS3 change into sending the HDMI signal, I'm sure though that is is similar as to the dvd player simply changing it in a menu. All I had to do was use a component cable to access the dvd player menu and from there changed the video out signal to hdmi, thus sending a signal to the frikkin tv. It all works now.
The Ps3 should have a similar menu to select video signal output. Try accessing it using a previously working cable, then once changed, switch on the tv back to hdmi input and see if it worked.
Hope this helps
Cheers
CPL Avila
SOURCE: cant find HDMI input on tv, trying to hook up ps3
hdmi output is" INPUT 1" on the menu ALSO hold down on the ps3 power button for 6 seconds and it should come on. the ps 3 has a thing were you have to set it to send out in hdmi or comp.
SOURCE: No signal on my TV
try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
Please remember to rate my response if helpful.
