Question about Danby Silhouette DWC512BL Wine Cooler
One compartment is cooling, but the other is not.
The left compartment is cooling OK, but the right compartment is not cooling at all.....and flashing HI.
  • 1,170 Answers
Please provide more product details.
Posted on Jul 29, 2009
Where is the cooling fan relay located
In the engine compartment fuse block. Look at positions 7 and 8. There should be a diagram under the lid.
Apr 18, 2016 | 1999 Oldsmobile Aurora
What relay runs the cooling fan on 99 Toyota Camry
You have a single fan (with your engine main) relay on the left side of your engine compartment... and another (with you A/C fan) relay... on the right side of your engine compartment... that feeds through a thermal switch ... Both appear to be SPDT (Single Pole DOUBLE Throw... on the schematic).
Nov 30, 2015 | Toyota Cars & Trucks
In my Kia Cerato 2000cc, only heating of the driver seat is ok.the other sear not working. in addition to that, cooling of seats also does not work
Check that the wiring harness plugs under the seats haven't become disconnected. Next thing to check is that the harnesses have power when the controls for heat/cool are activated. Also check the interior fuse compartment for blown fuses.
Dec 03, 2014 | Kia Cars & Trucks
Can you tell me what a flashing # 4 means on the fresh food display,when I try to set temp.the flashing # 4 keeps coming back. the fridge temp. is too cold and freezes everything.
Hello Bryce,
I found a manual, although I cannot be sure it is for your exact model, it is located HERE. This is what is stated under "Temperature Adjustment"
IF TEMPERATURE DISPLAYS FLASH... If ever you see both temperature displays continously flashing, it may indicate that the control system has detected a performance problem. Call your service representative, who can interpret the flashing message. To maintain temperatures, a fan circulates air in the refrigerator and freezer compartments. For good circulation, do not block cold air vents with food items.
This is located under "Turning the Cooling System On and Off"
TURNING THE COOLING SYSTEM ON AND OFF You can disable the cooling system in your refrigerator by pressing the On/Off button located on the left side of the temperature control panel. To ensure that you do not accidentally turn off the cooling system, the button does not work unless you press and hold it for three seconds. Once you disable the cooling system, all refrigeration to the freezer and fresh food compartments stops. To turn the cooling system back on, you must again press and hold the On/Off button for three more seconds.
If the manual I selected is not the one for your particular machine, there are others located HERE. There are various ones only differing by a "upgrade" letter on the end, perhaps for different models of different manufacturers, produced by the same company.
I hope this is of some help
Joe
Sep 20, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a 2002 Sunfire slx,when I try my turn signal the left side the internal light stays on and the flasher does not flash, the right side works ok. ? is the flasher relay under the hood or inside...
I would start by making sure that all your bulbs are good as a bulb that is bad can cause the flasher not to "load" enough to flash the lights. You might try turning on the warning/hazard flashers and making sure that all the bulbs that need to flash are flashing. The flasher for your car should be located under/behind the left side the dash near the steering column. It's probably an electronic type and may look like a small black cube. They can be quite hard to find under there. Hope this helps a bit!
Nov 28, 2010 | Pontiac Sunfire Cars & Trucks
Where is my relay at to my fan ?
the relay should be in your main relay box under the hood or in you main fuse box
Aug 19, 2009 | 1997 Pontiac Grand Am
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Cant find fuse for cooling fan
the fuse box for this car is located on the left rear corner of engine compartment and also has a relay centered on the right rear corner of engine compartment and 1 located behind the right side of the dash
Oct 21, 2008 | 1996 BMW 318
Danby Silhouette DWC512BL Wine Cooler Logo
78 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
