Question about Konica Minolta DiALTA Di200 Copier
C0F32 error displayed in new machine just in 25000 copies
The developer, drum is new infact the whole machine is new still C0F32 is displayed. ATDC auto adjust function is not possible due to error code.
  • unitech9474 Jul 29, 2009
    i myself is a dealer. i have installed the machine. i want technical assistance / advice for the problem
  • Konica Minolta Expert
  • 1,326 Answers
Is the copier is brand new out of the box? If so you have to call a dealer or a good friend that works on them to help you by pass the set-up error code. They put that little curve in to stop none dealer from installing there copiers.. Good Luck......
Posted on Jul 29, 2009
Konica minolta b163 has this code cof32, how to take it out?
Hi
I have found your problem here:
Error Codes Konica Minolta bizhub 163 Code C0F32
and it says:-
Code:- C0F32
Description:- Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Remedy:- 1 Check to see if developer is available. 2 Check the ATDC Sensor connectors for proper connection and correct as necessary. 3 Change UN1. 4 Run ?gATDC Auto Adjust. 5 Change PWB-A. 6 Change PU1.
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Konica Minolta Office Equipment & Supplies
How can i solve error code C0F32 in konica miniolta 7118
Press [Utility] -> [Stop] -> [0] -> [0] -> [Stop] -> [0] -> [1]. Go to [Adjustment] --> [ ATDC Adj. ] [Start], wait for 2 mins. it will automatically stop then turn Off / On copier. If C0F32 appear replaced the ATDC sensor located under the developing unit then calibrate again.
Oct 16, 2014 | Konica Minolta Konica 7115 7118 Compatible...
Service call c0f32 in bizhup 211
http://www.officeimagingsystems.com/id169.html
C0F32 - ATDC sensor problem
Try to change the developer of the machine. If it does not fix the problem, maybe there is a sensor fault.
Mar 07, 2014 | Sharp AL 1631 Copier
How do i reset ATDC in konica7118
has the developer and drum been replaced,? Where the counters for the drum and developer cleared prior to installing them? Was the Toner density procedure run after install, prior to any printing fax arriving or copies
Jan 28, 2014 | Konica Minolta Copier Tnr,...
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
I have a Develop ineo 161, problem is erorr cof32, please give me advice how fix that terrible mistake
C0F32: Faulty ATDC Sensor
Gently swing the IU in the horizontal
direction to even out developer
in the Developer Mixing Chamber.
Clean ATDC Sensor (UN1).
Change ATDC Sensor (UN1) and
developer.
Change Master Board (copier:
PWB-A).
Jul 07, 2011 | Office Equipment & Supplies
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Minolta di20 c0f32 error?
C0F32 Faulty ATDC Sensor E1
The value of data read by E1 is faulty. [E1 reading is 7% or
less (3.92V or more) or 19% or more (1.41V or less).]
C0F32, C0F33
Are PJ40, CN50, CN17, and PWBA
PJ15A connected properly? Connect them properly.
Is the CN50 connection dirty? Clean
Is “C0F32” or “C0F33” displayed
even when an I/C with the same T/
C as that of a new one has been
installed? Change the I/C with a new one
installed and an F8 operation run?
(Be sure to record the ATDC control
voltage setting value if an F8 operation
is to be run.)
YES Change PWB-A, install the old I/C,
and return the ATDC control voltage
setting to the value recorded. If
“C0F32” or “C0F33” redisplayed,
change the I/C with a new one.
is to be run.)
NO Change the I/C with a new one.
Jan 25, 2010 | Minolta Office Equipment & Supplies
Code error fo32
My think your error C0F32:
PJ15A connected properly? (NO) Connect them properly.
Is the CN50 connection dirty?(YES)YES Clean.
installed?(NO)Change the I/C with a new one.
is to be run.) (YES) Change PWB-A, install the old I/C,
change the I/C with a new one. (NO) Change the I/C with a new one.
if you are not tech pleas call your tech service.
Nov 26, 2009 | Konica Minolta DiALTA Di200 Copier
Fixing code cof32
The excess toner is under cleaning blade.Posible you emptied the developer.COF 32 ATDC sensor malfunctions.Tray ATDC gain level from 155 to 168.
Apr 22, 2009 | Minolta Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
958 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
