Question about HP OfficeJet 6110 All-In-One InkJet Printer
Problem printer i have Hp officejet 6110 all-in-one.when i'm turn it on the printer i got a message in LCD screen "original jam "clear jam,and then press enter "why i can the clear jam of the original jam
The display says clear original jam but there is no jam
You may need to check again. Even a tiny piece of paper left from when you cleared the jam will cause the printer to continue showing a jam. Make sure to also close any doors firmly.
Mar 08, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The printer has a message saying clear paper jam but there is no jam - how do I clear this?
Try this website:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00107909&cc=us&lc=en&dlc=en&product=79477
Nov 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Says Door Open. And it's not. Then it says clear
The following link to HP's website will give you step by step instructions on how to resolve the carriage jam issue:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00310245&lc=en&dlc=en&cc=us&lang=en&rule=29041&product=79477
More information regarding resolving issues on your OfficeJet 6110 can be found through this link:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=79477&lang=en
Apr 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The LCD screen on my HP OfficeJet 6110 All-In-One displays the following: Open Door Clear Carridge Jam, then Press ENTER Have changed all cartridges, cleaned inside the printer with pressurized air, tried...
apply greese material on the steel rod on which the carriage moves.or it could also be the problem of the sensor which detects the paper in the printer ,that sensor is moved from its orignal position.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Original jam message
A semi-full reset returns the user settings to the factory defaults.
It also deletes the following information:
* Language and country settings on some models
* Fax logs
* Fax headers
* Fax speed dial information
To perform a semi-full reset first unplug the power cord, then press and hold the "#" and 6 buttons on the front panel keypad while plugging in the power cord.
Feb 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
