Question about Iomega 1TB Desktop USB 2.0 Hard Drive
The word 'windows does not recognise' appears when i connect it
To a system
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
My windows 7 computer will not recognise my olympus x-42 camera
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Sep 25, 2012 | Olympus X-42 Digital Camera
My pc wont recognise my camers
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Aug 25, 2012 | Fuji FinePix S3100 Digital Camera
I'm using Windows 7 64-bit. All the Leapfrog software for my tag pen is installed and up-to-date. The drivers are installed, up-to-date and recognised. When I connect my tag pen and the Leapfrog...
I am having the same problem, contacted Tag (who is only there during work hours which really does not help) they supplied me with an alt connect file. That did not work either. Have you found a solution yet?
Kat
Jun 01, 2011 | LeapFrog Tag Reading System
Cyber-shot DSC-W55 Digital Camera: DSC H26 does not get recognised in Window 7...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 18, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
Can't connect to PC
(for windows only)
1- connect ur device in the computer.
2- go to my computer.
3- in the left task pane click system information.
4- the system properties dialogue box will appear.
5- click the hardware tab and then the device manager.
6- the device manger dialogue box will appear click on the portable devices and click the name of your device.... the device dialogue box will appear.... you will see the device usage....
7-enable it... and then click ok....
thats all....
Jun 07, 2009 | Goodmans GPDR40 Digital Media Player
Not recognising in computers
download and install the firmware for your mp3 player on your windows xp operating system and then it should work fine heres the link to get the firmware
Jun 02, 2009 | Sony NWZB133F MP3 Player
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Easy tranfer of files
Vista?
Problems with usb or others?
Otherwise You can visit this site:
http://downloaddrivers.net/?s=g
BUT BE CAREFUL WITH DOWNLOADING TO DON"T CACHE A VIRUS
Jul 24, 2008 | Microsoft Windows Vista Ultimate Edition
Device not being recognised - USB device not recognised...
Are you running windows media player on Vista, if so I'm having same problem. Appears one needs Windows XP, which is rather annoying..
Jan 31, 2008 | Samsung YH-925 MP3 Player
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
