Question about Dell 1.44 MB USB Floppy Drive (1y513) External Floppy Drive
Dell Internal / External USB Floppy Drive 1.44Mb *NEW* is this suitable to use as a external floppy disk drive for Dell Dimension C521 computer
  • Dell Master
  • 32,281 Answers
Any USB external Floppy drive will work with any computer with a USB port, but if you have Windows 98 you will need an USB driver.
Posted on Jul 29, 2009
I need a usb external floppy drive for windows 8 64 bit computer
Amazon com Sabrent External USB 1 44 MB 2x Floppy Disk Drive FL UDRV...
The above link has info on the drive. If you do a search " external floppy drive windows 8" you'll get several sites listed.
May 07, 2014 | IBM USB Portable Diskette Drive (05K9276)...
Where is Floppy Disc Drive A located on the PC?
This notebook does not have a floppy Disc drive, the CD or DVD drive performs the sme function
Jan 04, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Diskette Drive Failure for Dimension C521
Most C521's have no floppy, if you have none:
boot to the BIOS, (F2 at boot) go to the drives setting, diskette (May be listed as floppy disk drive) set to NONE, exit and save settings
Apr 10, 2010 | Dell Dimension C521 PC Desktop
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
Connecting internal Floppy drive as external
There are external cases that are mad just for this purpose.
Try Tiger Direct under external cases
Aug 25, 2009 | Samsung SFD 321B (SFD-321B) Internal...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
It would appear that you may need to do a couple of things in order to restore the drive back to normal. I would disconnect the drive using the icon provided to this effect and doing it after the message says it's safe to disconnect it.
If the message says differently, I would still disconnect it, unles you're in the middle of writing, which you're not.
Upon reconnecting the drive, should the condition persist, I would recycle the laptop and try again. It does not make sense that a disk that you recently read from to burn a CD is no longer readable, unless the mechanism inside the drive had collected debris that caused the data on your floppy to be ruined. That would be an unfortunate disaster.
If rebooting the laptop still fails to read the disks, then try blowing any dust or dirt from inside the drive using one of those small canisters of compressed air that people use to clean their keyboards and other devices and try again.
Should the condition persist, try loading the floppy disks on another system to see whether they've been ruined by your drive.
If they are readable, then the drive would appear to be deffective.
My floppy drive tells me to insert a disk when I try to use it
Sounds like you have a bad drive or the disk is corrupted. Did you try a different floppy disk to see if the drive is functioning?
Mar 21, 2009 | Computers & Internet
Floppy disks are formatted but when inserted it tells me it isn't formatted and I cannot format then because all the information will be lost. Can you help?
This often happens when the Floppy Disk drive head is faulty or out of azimuth. Usually when this happens you need to replace the froppy disk drive unit, which is not an expensive part.
If you do not want to take apart your PC to change the internal FDD, you can also buy an external USB floppy drive, in this case ensure you have a free USB port on your computer.
Here is USB external FDD:
External Floppy Disk Drive - Black
Here is internal one:
1.44MB Floppy Disk Drive
Jul 06, 2008 | Computers & Internet
External a drive
Make sure there is nothing inside before inserting a new disk.
Also, try to get one of those disk drive head cleaning disk and run it.
Mar 10, 2007 | TDK External USB Floppy Drive FDD-100AX...
Dell 1.44 MB USB Floppy Drive (1y513) External Floppy Drive Logo
577 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
