Question about HP Scanjet 3770 Flatbed Scanner
My scanner shows patches of green at the bottom
The first 3/4 area shows a clear i mage while at its bottom the scanner creates a green patch on the document which makes the whole document lose its meaning. Please if any one has a solution for this problem, i will be eternally greatfull to know, because the scanner is expensive to replace. thank you.[ Hp deskjet 3800]
  • 724 Answers
Try a scan in just B&W see what happens
and try to use the software to scan just a part of the work
Posted on Jul 29, 2009
How do I smooth old flooring adhesive enough to put new floor tiles on it
Depending on the size of the room you should use a floor sander or a buffer with a abrasive pad to smooth the serface to your liking
Mar 11, 2014 | Building Materials
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
There is a green patch in the bottom right corner of the screen.
Magnetic field prob.move the tv all around to get better or help less green color patch.Like move north south,southeast,southwest get less magnetic field interferences.
Oct 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Running Rage of Mages 2 (old game) on Windows XP
load on a windows 95 or dos box patch check the condition of the disc as well as the slightest marks make it probable error when loading old games
Aug 03, 2009 | Interplay Productions Rage of Mages 2 for...
I never had a problem using the HP Director button to scan until just recently when I get no action when clicking on thr desktop button.. I run windows XP Number Q3190A listed on the bottom of the scanner.
My Director shortcut button on the desktop did the same thing a few years ago. There is a patch to download on the HP website to fix it. Not sure of the number of the patch, but if you search , you should be able to find it!
I have other problems with mine, no power. Hp shows no power cord replacement because it is discontinued model now. I think it's time to buy a Canon scanner!!!
Good Luck!
Feb 20, 2009 | HP scanjet 3970 digital flatbed scanner
I have and love Scan Snap S500 on a pc.  I am transferring to a Mac.  I downloaded the Scan Snap for Mac S510M.  The program installs fine, but does not open.  The icon shows a big red line through it.  ...
Check out:
http://forums.macosxhints.com/showthread.php?p=527817#post527817
Thelatest Fujitsu ScanSnap V2.2 L11 drivers have been patched by me to work withS300, S500, S510 and fi-5110EOX/2/3 PC-based scanners for the MAC. Noneed to buy a new scanner. Just apply the patch and then send me aChristmas card! ;)
Hope this helps!
Jan 16, 2009 | Fujitsu ScanSnap Manager
My patch tool is working in reverse!
I just opened Photoshop, and tested this.
The patch tool works like this. You circle the portion of the image you want to use to cover the "white" area. Once you circled that area, you drag the selection to the "white" area.
Hope this helps.
Dec 02, 2008 | Adobe Computers & Internet
Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
Sounds like your LCD panel has gone bad.
If the unit is under warranty, take it to a Samsung repair shop. If it is not under warranty, go buy a new one. LCD panels are usually more expensive then buying a whole new monitor.
Mar 21, 2008 | Westinghouse L1975NW Monitor
Laptop's LCD Panel showing a vertical burn-in patch (Picture Attached)
Try updating your display driver.
Generally the computer should be updated as far as the drivers is concerned.
Check on line at the website of this laptop for updated drivers.
Check these before you do anything else.
Jan 31, 2008 | Acer TravelMate 2300 Notebook
HP Scanjet 3770 Flatbed Scanner Logo
129 people viewed this question
Seeker5211
Seeker5211
