Question about Xerox Phaser 6110/B Printer
PRINTER IS OVER HEATING WHEN IN USE. STEAM COMING
PRINTER IS OVER HEATING WHEN IN USE. STEAM COMING FROM PAPER OUTLET
    Master:
  • Xerox Master
  • 553 Answers
May be moisture in paper. If its then printing continuosly steam will come out. this is normal while the printer used at or near coastal belt. Pl. check out water slipage inside the paper tray.
Thanks
baba sanayananda
Posted on Jul 29, 2009
Just got followed instructions its not heating up and no steam
Is there any light coming on? Could be that there is no power to the iron. Check the plug fuse and the wall outlet.
Jul 25, 2015 | Irons
My iron is not heating up but steam is coming out
see this causes and fix it .God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.See the heating elements for open.
Oct 02, 2012 | Tefal Irons
Printer releasing steam after each page printed. heat coming from printer top
If steam is being released then the paper you are using is damp with moisture.
The fuser in the printer fuses the toner onto the paper, that process require a fair amount of heat.
Dry paper does not give off steam, use fresh dry paper.
Sep 02, 2010 | Samsung ML 2010 Laser Printer
No steam is coming out of the outlet in the steam room, but alot of water comes out of it
Check the breakers that feed power to the unit--turn off, then on. If no help, remove power from the unit and measure the resistance of the heating element--it should measure somewhere around 20 to 30 ohms, but not infinity. Hope this helps!
Apr 09, 2010 | Steamaster Steamist SM-8 Fixed 8 Kilowatt...
Steam is coming in car through heating vents
this would be a bad heater core. this is located under the dash on right side inside the heater box next to the blower motor the steam is acctualy radiator fluid that runs through it.
Jan 02, 2010 | 1991 Buick Park Avenue
Over-heating printer
Sounds like your paper has moisture in it and your fuser is heating it up. The fuser has soft plastic rollers, which is what you are probably smelling.
Try using an unopened packet of paper and see if you get the same issue.
For better storage of open packets of paper, store them in a dry, dark place, or in ziplock-type bags.
Dec 08, 2009 | HP LaserJet 1018 Printer
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Steam sauna (mr Steam ms400tc1). Unit fills up then allows water to exit via steam head without heating up to steam. Unit should stop water entering heating tank when full, heat up to steam, then allow...
If that unit has a steam valve I'd suggest checking it to ensure it's not stuck open. If it is, the steamer will not build pressure also. Should be a gauge for tank pressure that will show if it has built up pressure. If the valve is stuck open, it may certainly just dump water instead of steam. It's possible the water level sensors are allowing too much water into the tank, and as a safety it dumps. I've changed steam valves quite often due to the amount of heat they have to deal with.
Sep 16, 2017 | Heating & Cooling
Xerox Phaser 6110/B Printer Logo
142 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
