Question about Nokia N73 Cellular Phone
My n 73 get fall into water
My n 73 gets fall into water which is under warranty .but i opened it ....It's keypad is not working .
Is there will be warranty?
what will problem to keypad?
What will be expenditure?
.....plz reply fast i'm in hurry
My nokia model no 7230 fell in water after that every time the mobile turn on but after that no key works.
If you open your cellphone after falling it to water,its possible to damage the keypad circuit because of shorted happened in the circuit board when it fell, so better to look for a cellphone technician to troubleshoot it to avoid major problems.
May 29, 2011 | Computers & Internet
My mac does not work because of condensation problems, Apple will not cover it under warranty why?
Apple will not fix anything on your computer, because that falls under their "We won't touch your computer cause you water damaged it clause" Its in their policy in very small print.
After the Apple dork opens your computer and sees that the water sensors have been triggered they will put it back together and hand it right back to you and say, "Sorry you water damaged it."
Oct 31, 2010 | Apple MacBook Pro Notebook
Water problem with nokia 6300
my nokia 6300 has fall down in water then i switched off and on continuously at starting keypad worked then keypad stopped working after some time
Aug 03, 2010 | Nokia 6300 Cellular Phone
How can I fix my phone when the keypad doesn't work?
how old is the phone under a year with no physical or liquid damage you can get it replaced under warranty by calling 1-800-801-1101 (at&t xchange by mail)
Jun 06, 2009 | Pantech Matrix Cell Phone
Display not visible
Change your Display ic or L.C.D if broken Thanks
Apr 27, 2009 | Nokia N73 Cellular Phone
Keypad not working
sonyericsson w810i kiepad not working
Sep 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Nokia n 73 all keypad not working
sir i am tahir from kuwait.sir pres 1 key not open .open this 5 key what problem / chang the ic same problem/
Sep 02, 2008 | Nokia N73 Cellular Phone
N 73 keypad not working
hi my n73 key2 not working
N 73
hi dear.
open the pad and clean its contacts. below is the proceedure to open the phone (if it is not under warranty). you two credit cards and a screw driver.
1- Take front faceplate off by inserting card 1 between housing and silver key. As you pull up, take card 2 and slide it on the side of the phone prying the clips off.
2- Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen.
3- Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover.
4- That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
gudluck
Aug 31, 2008 | Nokia N73 Cellular Phone
Keepad notworkig
boy o boy,this is not gud...u can only do one thing bro, get ur fone checked in NOKIA CARE CENTRE and only they can fix it.. cuz probably water has damaged the inner padding..dont not the extremity of the damage n if the fone is in warranty u dont have to shell out money but if the warranty has elapsed then the CARE guys would tell u the cost of repairing and all. I hope this solves ur issue. PLEASE DO RATE IT.
Jul 12, 2008 | Nokia N73 Cellular Phone
Nokia N73 Cellular Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
