WATER LEVEL HI there, This washing machine I found in the dump,she looked to good,so I took it home connected to water and power and she went no problem. Only while spinning a bit rumbling,so I replaced both bearings and seal,put all back together and she sounds like new. But I think there is not enough water.I 'd like to ask you how much water should be in there and also How can I adjust it? Best regards Tom tomas_kellner@xtra.co.nz
  • SRSwirl Nov 26, 2007
    Is there a way to modify the water level of the Bosch Nexxt 700 WFMC6401UC?
  • 447 Answers
What kind of washer is this ???? Front load??
Posted on Nov 23, 2007
I took my whirlpool washer a part I found a sock stuck where the water hose in an out. But now I for got where the smaller hose connects to
I don't know what you are looking at, but there is a small usually clear hose that connects to the water level switch. It is located high in the unit and has a two wire harness
May 14, 2016 | Whirlpool Washing Machines
Leaking water from washing
The next thing you should check is the discharge hose where it dumps into your house wastewater system. If you can not be in the immediate area for a wash cycle then wrap a paper bag around the dump location. Hold the bag in place loosley with string or rubber band.If the paper is wet when you return you have found the problem.
Do NOT seal the dump hose to the wastewater pipe.This can cause the problem of filling the machine because there will be a vacuum that will siphon the water out.
Jan 17, 2014 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
LG MW3677HW Water Inlet Issue
I am not clear on how you connected that machine to the water heater. IT sounds to me like the machine does not know that it has water in it. IT would not normally open and dump the water if it did.
Dec 16, 2013 | Washing Machines
Kenmore water keep running will not wash
On many washing machines, there is a water level setting switch. This allow you to adjust the level in the machine to converse water. This switch works on air pressure. There is a small hose inside the outer drum at the bottom of the washer. It is connected to the pressure switch (level setting switch). As the washer fills, the weight of the water compresses the air in the hose until the pressure switch activates. There are two possible failure scenarios; they are both fairly easy to repair. First, the hose could be blocked at the drum entry point by lint or debris. This is a somewhat common occurrence. To check this, unplug the washer. Remove the rear cover from the control panel to access the rear of the switches. Find the rubber hose attached to the level switch and remove it. Blow through the hose to clear it. Reattach the hose and retest the machine. If that doesn't work, you may need to replace the water level switch, It is easily remove and replaced once you have accessed the rear of the unit. You can calls Sears service with the model and serial number of the machine and get replacement parts sent directly to your home.
Jan 01, 2012 | Kenmore Washing Machines
My washing machine would stop and beep and not advance to the next wash cycle and it was taking forever to fill up. I did the diagnostics and found it to be #49 which is a faulty hot or cold water valve. ...
Sorry for the very much delayed response due to site changes which modified the notification system.
Anyway, you should try holding first the WASH TEMP DOWN button then the POWER button until there's a beep. If it doesn't work, use WASH TEMP UP instead.
Make sure the Restart feature is turned on and the Recycle feature is turned off if all else fails. During the diagnostic mode use the WATER LEVEL DOWN button to turn RESTART on by pressing the said button until the LOW WATER LEVEL LED turns on. Use the WATER LEVEL UP button to turn RECYCLE off. The MEDIUM WATER LEVEL LED off indicates RECYCLE OFF. To set these modes in EEPROM the Advance button must be held while selecting Restart or Recycle. Power off the machine thereafter to complete the reset.
Oct 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a Roper washing machine (Model: RTW4440XQ0, Serial #: C11740048) that is less than a year old. When you start the machine on any cycle (on high water level) it will fill up with water and run...
The machine was built to adhere to the low water guidelines of your overly intrusive government. Bought a new machine with the same problem. 1/2 tub of wash water and 3"-5" of rinse water. 3 different local service shops and the Whirlpool people said neither was adjustable. I found this unacceptable and decided I was going to make it work the way I wanted not the way the government schlocks said I must. Took out the 2 screws on either end of the control panel ( where all the controls are) lifted it up and found 2 ADJUSTABLE water level control switches. One 3-way for the wash water and one for rinse water. Cranked them both in and now I have a full tub of wash water and the same for rinse, Vote in 2012 to keep the government out of our homes and our lives,
Sep 14, 2011 | Washing Machines
My washer continues to dump water and over flows. Also wash cycle not working at all. Rinse and spin ok
You have a problem with your water level switch http://www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
When your switch is not working, the washing cycle will not trigger to operate.
Check your water level switch for your model, look for model number under the hood of washing machine, at the sides of washing machine, or in the back..
Mar 10, 2011 | GE Washing Machines
Ken more wot stop filling but think i got it want to make sure
A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Mar 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series will agitate but not spin or let water out.
Hi, I know washer had a party, he just need a dancing partner, joking, that's a common problem, when machine is not properly level, you should used spirit level, to level machine, after leveling machine, place both hands on machine, and try to rock it from left to right, forward and backward, and it should not have any play, if there's play adjust legs to compensate, water has to be pumped out first before machine spins, rhere's something wrong with water pump, maybe some fabric stuck in pump impeller, or maybe wires disconnected from water pump, remove back of machine and check connection to water pump, check for kink hoses, visual check, if wire were remove, connect to water pump, you're smart. good luck.
Aug 08, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking washing machine
it sounds like your water level is sticking and may need to be replaced
Jun 02, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
196 people viewed this question
Top Washing Machines Experts
