Question about Compaq Evo N600c Notebook
Can I install larger then 40GB hard drive in a
Can I install larger than 40GB hard drive in a N600c?
    Problem Solver:
  • 12 Answers
Yes you can install a larger hard drive in this model laptop.
Posted on Jul 29, 2009
The 261380-001 HD for my EvoN600c is dying. Can I upgrade to a larger capacity drive as long as I stay within the 2.5"/9.5mm size? Can I go to 100 gb?
As far as I am aware you can use a 640Gb drive if you can get one but that is a little too large!
120Gb should be fine.
Mar 22, 2011 | HP Compaq Evo Notebook N600c
I bought this machine refurbished from amazon.com and it came with a 40GB hard drive. When i try to put a larger one it and install windows it recognizes the hard drive but after copying files is done, it...
This machine can't use a hard drive larger than what it came with.
This is a very old machine and won't be able to run anything more than Windows 2000.
About the only thing that is current and will run worth a darned is Linux. With Linux you'll be able to use the larger hard drives as well.
Dec 24, 2010 | IBM THINKCENTRE A50 - P4-3.0GHZ/1MB 800MHZ...
Hi. I have lost my adapter and connectors to connect my smart disk HD to my Macintosh power book (g3 model). The model # on my disk drive is FWFL80-N. Has another # which is JH7X04. Where can I find...
You could buy a disk-drive-to-USB adapter, and connect the "bare" disk-drive to a USB port on your computer, and then copy all the files onto your computer.
See: http://cgi1.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=190391564434
for under $5.00 for such an adapter.
Or, you could spend about $40 to buy a brand-new enclosure & AC-adapter & cable that is "empty", and then you could "transplant" your 40GB disk-drive into that enclosure, without losing any data on the disk-drive. Then, copy the files, and then remove the disk-drive, and purchase a new, larger, disk-drive, and install that into the new enclosure.
Given that your disk-drive is "only" 40GB, it's probably getting old, and is "out-of-warranty", and thus should be "retired" before it completely fails.
So, the best solution would be to buy a brand-new, much larger, external storage device.
Nov 07, 2010 | SmartDisk FireLite 40 GB Hard Drive
Acer vt7500 with a s88m motherboard and xp pro The hard drive(40gb) is failing and I would like to know what I could replace it with (ie. largest size) and install xp. I do not need to save the old...
Your 40GB drive is an IDE ("Integrated Drive Electronics") drive.
The largest IDE drive ever manufactured is 500GB.
However, some motherboards do not support drives larger than 320GB.
Some disk-drives (Seagate/Maxtor) come with a CD-ROM of "tools" that enable you to copy "everything" from your "old" drive to your "new" drive.
Oct 26, 2010 | Computers & Internet
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
Is there a larger hard drive for the Toshiba Satellite A55-S1063. the hard drive that came with it is 40gb?
Go to their website and check under this model for upgrades. If not go on the Net and look up the upgrades from there. Good Luck
Mar 07, 2010 | Toshiba Satellite A55-S1063 Notebook
Syntax SV266A Motherboard Hard Drive update
i,d suggest an 80-120 gig hard drive should be sufficent.
if you require larger drive storage. you can add an external hard-drive via USB upto 500 gig usually without restriction.
You can also purchase An PCI Card, with sata connectors. should you wish to take that option. all the above is dependant on how modern your computer system/systems bios Is.
Mike @ Compurepair.
Mar 25, 2009 | Computers & Internet
HDD replacement for Toshiba Satellite M35X-S114
should be no problem adding a larger hard drive....If I were you I'd compare some prices of Hard drives and choose the one thats suits best...you're not restricted to toshiba hard drives either....advantages of installing a larger hard drive really relate to what you use the laptop for....if you store lots of music or have lots of big programs then a larger hard drive makes sense....also you'll find it easier to get a 60gig hard drive than a 40gig as that size of drive is quite rare nowadays
Dec 17, 2008 | Toshiba Satellite M35X-S114 Notebook
Reboot
You can insert the OS installation CD and hit F11 or F12 to get to the boot menu. The you can wipe out your hard drive and put a fresh copy of windows on it.
Apr 18, 2008 | Compaq Evo N600c Notebook
Compaq Evo with wpc54g v.1 wireless adaptor
hello!
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
Apr 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Compaq Evo N600c Notebook Logo
87 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
